Long Tube Header Install 1st time rookie
thewicked5oh
nebraska USA
selvin
Hey yall going to be installing my long tube headers on my 19’ PP1 10r80 5.0 been watching videos looks difficult any tips or tricks before doing this myself ? I’m not a mechanic by any chance just a guy not wanting to pay 1000+ to a shop for the install a fellow DIY’er (I don’t have a lift going to use jackstands)
I Bleed Ford Blue
North East OHIO
I've done this twice, both times on jack stands. The gen 3 engine (18-23) has a plastic oil pan so you will need this https://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html to support the engine from above, also get yourself a stretch belt tool to remove and reinstall the belt on the A/C compressor. Then you can unbolt the comp and lay it out of the way so you can get the new header in with out removing the studs, otherwise you have to pull 6 of the 8 studs on the passenger side and it's a nightmare to get the studs back in after you put the header in place.
Pistol_91
Clearwater
2020 mustang GT
Make sure you have some bolts to replace some of the studs. Good luck. It's a bitch.
thewicked5oh
nebraska USA
selvin
Good looks on that part ima do the good ole purchase and return special 😂
Sparky1337
VA
2016 Ruby Red GT
Do you not have to unbolt the steering column on the 18+? I remember that being the biggest pita on the 15-17’s.
I Bleed Ford Blue
North East OHIO
you still do, but it's just 1 bolt.
I Bleed Ford Blue
North East OHIO
Just pop off the belt and unbolt the comp so you have room to get the header in, DO NOT open the lines, then you have to have the system recharged.
HKusp
Hampton, Md.
Jason
Some of the worst time I ever spent working on this car was doing those headers. It ABSOLUTELY sucked.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
I am pretty handy with a wrench, and I paid to have mine done. Mechanic (friend that does Coyote headers several times a week), he picked it up at 8 am and had it back to me by 6 pm that night. Best money I ever spent.
thewicked5oh
nebraska USA
selvin
Yall making me want to pay at this point 😂😂😂 come on yall suppose to encourage the DIY
