Just ordered Antigravity Lithium Battery
Ixse
Socal
2016 gt350
Hhey guys, need some help. Bought atx20hd w terminal adapters. But adapters only came w one screw. Don’t think this bolts up to the square prongs. Any idea??
Demonic
Demonic
Boston
GT350R
You mean one screw for each terminal right? The square terminals on the battery should be threaded or if they aren't, there should be room to slide a square nut under, so you just screw the bolt through the cylinder terminal into the square terminal on the battery. I'll look again when I get home.
Tomster
Beware of idiots
Tom
My battery came with a bunch of nut inserts. Did you throw the box out? There is a small plastic bag that came with the battery that has the parts you need.
Ixse
Socal
2016 gt350
Found it! Stupid me, wasn’t looking at the other bags.. thanks for all your inputs
Ixse
Socal
2016 gt350
Ok.. new problem.. atx20hd. First day of was no problem, voltage was stable at around 13.2. Let the car sit for a week. Today i started up, and voltage started to fluctuate rapidly between 13.7-15.5. Idle it fluctuates between 13.7-14.7. Under acceleration it seems to go up to 15.5. My interior center console lighting fickered and radio turns off and on. What might be the problem? Checked the battery.. seems normal.. no sign of burns or anything..
Tomster
Beware of idiots
Tom
Did you charge it 100% before installing? Did you reser your battery charging circuit in forscan?
Ixse
Socal
2016 gt350
It was fully charged. Currently still fully charged. No i have not reser via forscan. Theres few members that didn’t have any issues w atx20hd w/o the reset, so i just let it sit for 12 hrs w key fobs away to let ecu do its own reset?
The funny thing is, just now (been about 30min since the fluctuation) the voltage stablized again at 14.1. And everything seems ok again. How weird
Tomster
Beware of idiots
Tom
I fully charged my battery with a ctek charger. Batteries are not full when shipped.
Demonic
Demonic
Boston
GT350R
13.2V doesn't sound like it was fully charged. If the battery has enough charge to start the car but then go into low voltage protection mode, the you'll typically see voltage swings and flickering lights because the car is effectively running off just the alternator and doesn't have the load balancing of the battery. You're charging this battery to full with a lithium specific car battery charger?
Tomster
Beware of idiots
Tom
My guess is not. That's why I asked.
Ixse
Socal
2016 gt350
Ahh.. but why zero issues On the first day of install?? I checked the battery charge status on the battery, all 3 lights showed up. Does this battery need to be completely topped off every time before start?
Demonic
Demonic
Boston
GT350R
Demonic
Demonic
Boston
GT350R
No, but definitely needs to be topped off with the charger on arrival. I'm not sure how accurate the led's on the battery are, but 13.2V is low for a lithium. A lithium battery charges faster in the car than a regular battery, so it gets topped off pretty quickly when you drive. But it likely wasn't fully charged when you put it in, and then after a week it still had enough power to start the car but went into low voltage protection after starting the car. Hook the battery up to a lithium charger overnight, until the charger reads 100%, not just the status button on the battery. Then report back.
Tomster
Beware of idiots
Tom
That battery indicator doesnt mean squat. You should have hooked it up to a lithium battery charger and charged to 100%
