JMS BAP wiring burned up - Almost leaving me stranded
NGOT8R
Adrian
2019 Bullitt
wingnutt
@FL410
michael
350R Procharged w/P1X
Yep (and no offense) but it happened because you ran a BAP for 3.5 years 😉
even back in the 90s, we were told (by Kenne Bell) that the BAP was a temporary fix, and plan to eliminate it as soon as you can.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Copy that. None taken. I’m just glad things worked out the way that they did yesterday. Live to fight another day.
larr12
Alberto
2020 Mustang PP1
I was gonna say maybe something about the ground but @wingnutt reason sounds way better.
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
I have a new Procharger boost a pump lmk
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Thanks for the offer, but I’m going to repair the wiring harness on mine and reinstall it. Moving forward, I will only use it when making nitrous runs at the track. I will remove the fuse after nitrous use and rely on the DW400 for naturally aspirated use. This is the safest way to use the BAP that I can think of, now that I’ve discovered an area of concern.
found a post by @Zrussian13 a while back, where he mentioned that he also experienced a wiring harness issue with his JMS BAP and had to have them repair it. In the end, I believe he switched over to a VMP BAP though. He did say that he had also searched and couldn’t find reports of anyone else experiencing problems with the JMS unit.
Unas2k5
Detroit
Samer
Good luck ! I hope it works out for you!
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Thanks. I‘ve been wondering why the failure occurred at the weatherpack connector. I ordered a new one rated for 40A, since That’s what the fuse was rated at. I think I’ll be fine moving forward using the BAP sparingly once it goes back in the car. If not, I’ll let it live solely on the DW400.
