Stang left me stranded
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
Thanks for the care guys, an update as I just got back from dealer.
Apparently the clutch sensor connection came lose causing it to not start. Ford fixed it with ease and got my car back within a couple hours. I guess with new cars, electrical problems will be the death of me lol.
The adviser did say that this wasn't his first time encountering the issue.
I will post up some pictures of where it is, and actually show how to fix it. Just in case it happens to any of you guys down the road!
Overall, even though I was pretty upset ford fixed it AND offered a complimentary oil change. So thanks ford.
That would be much appreciated!
Thanks
Millgeo5
Tucson
Geoff
2015 Mustang GT
Glad to hear it wasn't anything serious
doulos4jc
......looking^
2015 Turbo Mustang
I'm assuming it was the switch. If so that's the switch I am going to try to tie my remote kill switch to. The switch itself has two wires and is a little flimsy, plasticy, so I can see it potentially failing. And it appears to have worked as a kill switch in your case...unfortunately. Glad it was a somewhat easy fix.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
Figured it was something dumb, glad you got it fixed with a quickness. In for pics.
Fox5.0
So Cal
2015 Mustang GT PP magnetic
You are correct sir. will post pictures tomorrow morning. I would advise all owners to tighten it up a bit.
Asharus
Boca Raton, FL
Angelo
2018 Challenger Scat Pack
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
My money is on someone on the assembly line didn't plug the harness into the switch all the way. I once rented a GM delivery/box truck from Penske Rentals. Truck only had 200 miles on it since it was still new. I was heading north up I-81 or 88 and was about 100 miles from the NY boarder in PA and a freak May snow storm hit, and hit hard. Shut down the interstate for 8 hours. When it opened back up, the packed snow was like a washboard. Truck was vibrating like crazy and the headlights started flickering off and back on. Pulled into a hotel, tried to fix it, but after 18 hours on the road, including 8 stuck in the snow and no where to lay down, I threw in the towel and got a room.
Next morning, finally managed to snake my arm behind the dash and get a grip on the wiring plug. It was loose. Snapped it into the socket and feeling how tight it went in, there was no way in hell it vibrated loose.
I chalked it up to an assembly line screw up on a Friday afternoon.
Asharus
Boca Raton, FL
Angelo
thank god my blend date was on a tuesday then
Old 5 Oh
Wilder, ID
David
2015 GT Premium AT
Sounds like a quick twist of a screwdriver might be good preventative medicine for you stick-shift types.
Wyldfyer
Ga
2017 Shelby GT350
Glad you got it fixed. I'm definitely interested in the pics.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Fox5.0
did you ever take any pics?
Old 5 Oh
Wilder, ID
David
2015 GT Premium AT
I have had a kill switch wired to the clutch in my 94 GT for years. Dead reliable and a lot less hassle than switching the fuel pump relay or something that actually has current in it. The clutch is just a continuity check so very safe to switch.
