JLT catch can designed to dump oil into intake?
RedGT45
Georgia
Kyle
2017 Mustang GT
The inlet side of the catch can has the honeycomb mesh that oil condenses on and then it pools in the bottom of the catch can. The outlet has no screen or filter. So what happens when oil is pooled in the catch can and you hit a bump? The catch can is under vacuum so I would imagine your intake takes a big sip of oil. The can needs a screen or something on the outlet.
What am I missing?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
What am I missing?
Like me, we're missing a much better catch can. I swear to God a 40 buck ebay one is much better than the JLT. I'll put that theory to the test soon.
Zathras
When I used a JLT catch can on my S197, I never accumulated more than maybe an ounce of oil in the bottom of the thing, and I don't think a normal road bump would really create much of a splash inside it. But it's an interesting thought.
3rdRGR
Indiana
Rick
2018 Roush RS2, 2011 Nissan Murano SV
I'd say if you are checking your can at least once between OCIs you won't be accumulating enough to worry about. Unless you roll it and then a little oil in your intake probably won't be the problem.
RasJeremy
Denmark
Ras
Mustang 5.0 2020
I have the JLT on both sides and I've never given that a thought. I can imagine if you drive thousands of miles between checking it, it could cause an issue.
I empty mine every 1000km (620 miles) and there is only around 5ml in it.
If that should be shaken and get sucked up, I think that the thing that caused the shake would have made far worse damage than a small amount of oil in the intake :crazy:
And for the curious ones - I only get oil in the passenger side - the drivers side is bone dry and has always been :thumbsup:
2016 Mustang GT PP
Ford Performance (for example) the outlet on the other side of the screen which acts as a splash baffle. I only empty it when I do an oil change. Still think its a better design than most of the aftermarket ones.
WildHorse
N/A or GO HOME
'17 S550
That's one reason why UPR offers check valves on theirs.
The PCV already has a built in check valve. Idle its almost closed. Cruising is halfway open. WOT its open. There's also backfire protection.
Andy13186
Catching any is better than catching none. Dump the can once every 6 months.. it doesnt fill that fast and even if its full it wouldnt drink more than stock amount. I dump mine every 1k miles but there is hardly any in there and I check my oil level every 500 miles.
3rdRGR
Indiana
Rick
Thank you for spending the money and letting folks like me know we don't really have to!
ihasnostang
MN
www.youtube.com
one could always design a baffle that seperates the inlet and outlet sides and sits a certain distance off the bottom of the can
Andrew@Lethal
West Palm Beach Florida
Andrew
2003 10th Anniversary Cobra / 2003 Ford Lightning
What am I missing?
The JLT catch can is great. You just need to stay on top of emptying it. However the UPR cans have a check valve built into the lines which prevent any unwanted oil being sucked into your intake. We sell both here at www.lethalperformance.com!
RedGT45
Georgia
Kyle
2017 Mustang GT
I ended up replacing my $150 JLT with a $25 catch can that has that baffle built in.
WildHorse
N/A or GO HOME
'17 S550
Well how would that work ? The PCV already has a check valve in it.
Andrew@Lethal
Andrew
