floydbanks28
Also for the RCA's you put in feeding the amp, is it a full range signal? Sorry for the dumb questions, I'm just making sure before I go ahead and assume and damage something.
I don't know what you mean by this.Once it was all done I cut one of the rear speaker signal wires and soldered in the RCA's.
I would agree with your last statement 100%! If I had paid that much for an enclosure and then had to tweak it to get it to fit, I'd have been all kinds of pissed!!!Did you run into a problem with sloppy fiberglass work around the mounting holes? Both of the bottom holes in mine had excess fiberglass/resin around the mounting holes so there was no way for the washers/fasteners to sit flat and seal the sealed box (what a concept, huh?). I spent an hour with a Dremel. Inexcusable on a box that cost what this does.
And worth every pound, IMO. Box sounds amazing for such a small, sealed box. And it takes up zero usable room in the trunk. That's what you're paying for; not losing any trunk space.the sub weight 15.0 and I'd estimate the box about 5-7 so around 20-23lb total
