Is the caster on the CFTP adjustable?
Tomster
Beware of idiots
Tom
I am about to dabble in a string alignment. Obviously tow and camber are adjustable. I don't see an adjustment for caster.
Is it adjustable?
Thanks
Epiphany
Global
I like to disassemble things.
Caster is fixed. The plates only allow for camber adjustment and as always, toe is adjustable via the tie rods.
With 7+ degrees of positive caster, the S550 is pretty well off. The range sucked on earlier Mustangs such as the Fox chassis that would kill to even attain half that.
Surfergeek
Silicon Valley
Jared
2020 GT500, 2004 Corvette Z06, 2020 F150 Platinum, 2019 Yukon Denali XL
With an aftermarket plate like Vorshlag, it’s adjustable, but the factory plates are camber only. Even the Vorshlag plates only give you +1 degree or factory.
As my base car didn’t come with camber plates I opted for Vorshlag for the added range of adjustability.
Camber/toe is infinitely more valuable on these cars.
Tomster
Tomster
Beware of idiots
Tom
thanks. That simplifies the matter.
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
It looks like the Base and the CFTP cars have a different caster. Would the spring height affect caster or is one of the suspension parts different?
Alignment Specifications
NOTE:
Measurements listed at curb load. Curb load is defined as "full service fluids, full fuel tank(s),
no passengers and no cargo".
Base - 7.81° ± 0.75°
CFTP - 8.08° ± 0.75°
Epiphany
Global
Earl, spring height absolutely has an impact on measured caster numbers. There is a direct correlation between spring height/ride height and the differing caster numbers you quoted.
Surfergeek
Silicon Valley
Jared
I just pulled up the alignment report from the track alignment I had done after putting in CFTP springs and my camber plates and the rest.
Caster is measured at 8.1 on my car (makes sense that it lines up with the CFTP setting now.
We kept Caster setting at factory in the Vorshlag camber plates.
