IS MY GT500 BROKE!?!?
2020GT500
Northwest Territories
Andy
2020 Shelby GT500
Service Dept just called to say they are waiting to hear from Ford on a path forward for my GT500 with just over 1800km (1100 miles).
Oil filter was collapsed and excessive metal shavings found in oil!
in addition to the filter collapsing, there is apparently a small piece of plastic at the bottom of the filter housing (filter alignment piece?) that has also broken.
Waiting for pics from service dept, and praying for the best case scenario.
Currently sick to my stomach.
Epiphany
Global
I like to disassemble things.
This is pretty much what was reported here a week or so ago, save for the excessive shavings. Was this indeed the original, assembly line filter or did you have it changed at some point since delivery?
2020GT500
2020GT500
Andy
2020 Shelby GT500
It is as delivered.
Epiphany
Global
See if they srill have the filter. Not likely, but it may have the incorrect filter installed. There are two filters that are near identical, one barely reinforced with plastic and the other, the correct GT500 filter, is internally reinforced with a perforated steel tube. The key is taking a clear shot of the inside of the filter to see. Call them and ask.
The filter may have been incorrectly installed by the Niche line builder as well. If not seated properly when tightening the filter housing, it can crush the "alignment piece" at the bottom of the housing and then it gets partially collapsed when tightening the housing. Get photos of anything you can. Clear photos that are in focus.
oregongt350
Oregon
Michael
2022 GT500 HE, 1967GT Fastback S code,
Thank GOD for new car warranties, hang in there,service departments can drive a guy crazy. I had the service person
ask me on my GT350 if I wanted synthetic oil ??? I looked at her and said yes............ its required by Ford and the owners manual.:flag::like:
V00D00
Dover DE
2020 GT500
Could be nothing. The other crushed filter car is doing fine.
If its your 1st oil change, id expect metal shavings in there as part of the break in process.
Hard to tell by words alone.
2020GT500
2020GT500
Andy
2020 Shelby GT500
2020GT500
2020GT500
Andy
2020 Shelby GT500
That was what happened when I called to book the appointment and again at the service counter!
Scoobs
Ontario
2017 MG GT350 sold, 2019 MG GT350R KR569
If you need a new canister housing hopefully it doesn't take too long to get to you.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
There were 36 of them in Detroit the other day. I have one ordered along with some filters and hope ol' Ford Pass will pick up the tab. :-)
It will, I picked up my canister and case of oil today using FordPass points.
Grey03
Ohio
2020 GT500, 2017 Raptor, 2021 BMW M340i
I can see the filter getting twisted if they are installing them dry during production. I have a 2017 Lincoln MKZ that has the plastic version of this filter FL2062. They fit pretty tight on both the plastic canister and on the engine and without oil they would twist easily during installation. This might be something that needs changed/checked almost immediately.
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Andy,
I feel really bad for you, especially after all the hoops you had to jump through just to get the car.
I hope this turns out to be better than it looks and you will be up and running ASAP.
Good luck and stay safe.
Earl
