Is high temp paint necessary on coil covers?
JJR512
Glen Burnie, MD, USA
Justin
2015 Ford Mustang 50 Years LE #1523
As the title says, I’d like to know if high temp paint is required for the coil covers, or if it’s ok to use regular body paint. (Also for the plastic engine cover.)
If I have to use high temp paint, is it possible to get custom colors, or am I limited to whatever is made?
Southview
Viera, FL
Herby
2015 GT Premium Convertible
Regular body paint is fine. 25 years in collision industry
Snake Plissken
middle of nowhere
2016 GT
No
High-Temp paint is not necessary. I painted my coil covers with off the shelf rattle can paint made to paint plastic. Two year later, it still looks great.
Elvis66
High Desert California
Brandon
2019 mustang GT ..2014 Camaro ..72 Chevelle ..67 LeMans..97 4runner..2001 tundra
No ..just use a good primer
3star2nr
Ray
2016 Ford Mustang GT PP
For the rollovers no. But i recommend using a flexible paint like plastidip.
That said all paints will crack, chop and look like shit in time
EFI
Masshole central
5.Br0
Take a look at the temperature rating of the regular non-high temp paint and see if it exceeds 200*F. If yes, then you don't need anything else.
High temp paint is usually for stuff getting to 500*, which is nowhere near what the coil covers will experience.
Blk2015GT
2015 GT
Had mine plastidipped black for years. I may have gone too thin spraying it (first time doing it years ago) as it came off in small pieces and needed a little thinner in spots to melt it off, but it came right off eventually. They cant get that hot then
Elvis66
Brandon
What color are you after?
abie915
Kansas City
'15 GT PP, '16 EB PP
I painted my coil covers using rustoleum primer and paint out of rattle cans. I've had them on for over two years and they still look perfect, no peeling/chipping/fading whatsoever. Just make sure that the can says that it's meant for plastic.
JJR512
Justin
Thank you everyone...I found out I can buy painted coil and engine covers from RPI, and they have all Mustang colors, including Wimbledon White, available. They can do exactly what I want, and I'll be happier with a professional job. But thanks for your help!
robwlf
phila
rob
17 lightning blue pp LFP 670
na i painted mine at work with rm diamont and rm clear and they have been great for over 3 yrs
