Condor1970
- Oct 4, 2018
- Port Orchard WA
- 2018 Mustang GT
Yes, correct. You may not even have to get a tune, since my 2018 Base GT actually has both gauges working without a tune. (Oil Pressure, and Vacuum gauge). They both appear to be working exactly as they should. Oil pressure at idle is about 30psi, which about what it should be. If the values seem off for some reason, then it may be prudent to take it in and have them calibrate the gauges accurately.Condor1970 -
I think I’m getting this right from reading this thread and others. So on a 19 GT base I would need (in brief):
New “4 hole” dash panel/insert
Block middle vent
Gauge pack
Fish the lead from behind the sync/stereo/dash
Maybe at tune to activate one or both
Correct?
Thanks so much in advance!
If you want to run the GT350 gauge set which has Oil Temp instead of Vacuum like on the Perf-Pack, then you will probably have to take it in, and have them adjust the programming to have those leads going to the vac gauge read the oil temp instead.
