Install PP Gauges on Non-PP Model - Recap
Bnewell101
North Carolina
Brandon
2016 mustang GT
I have a late year 2015 (vin claims 2016 production date is 8/15) GT premium and apparently I also do not have the plug and play wire for the gauges. Has anyone run into this and found the wire elsewhere in the dash? I'd like to avoid splicing as much as possible but I don't particularly want to go on a wild goose chase for a non existent wire
sonicblue2004
New Jersey
Alberto
2017 GT California , Roush Phase 1 S/C w/ VMP Tune
can you post a more clearer pic?
what happens if you stick small screwdriver through the square hole in the plastic structure behind screen, does it go all the way through? did you stick your hand behind the plastic structure to see if the wire fell out of square hole? not saying your wrong but I would be suprised if you don't have the wire on 17 gt premium.
Here’s a better pic. Not all GT premiums have the connector. I found out the hard way.
p6cl
Near Cleveland OH
Ray
2016 Ford Mustang GT Convertible
Ok I was told today that SCT tuners can't turn them on, only hptuners. Can anyone verify this?
My Tunes from Lund and AED are both for my SCT X4 Tuner and the gauges were enabled to work by both of them. They also have a feature where you can add the gear that the transmission is in to show all the time, for the analog cluster from both Tuners.
Mak_Batman
Tampa
2016 Mustang Ecoboost premium
I have a 2016 Ecoboost and the wire with plug attached was already there. It was tucked behind the radio, clipped behind a panel. The early part of this this thread shows exactly where it is. Once I plugged it in my boost gauge immediately worked and I needed a local tuner to change a setting for the oil pressure gauge to work.
Is your car a GT model?
bluestar
Illinois
2018 Kona Blue Mustang GT
Posted this earlier....Does anybody know if the PP gauges are plug and play on a base 18 GT?
bluestar
Illinois
Yes. I'm in the middle of doing mine. I bought the gauge, and it worked immediately with no tune. It may need calibration though...not sure.
So it does have the connector behind the radio area, correct? Thanks!
18usc371
Naples, FL
Jim
GT350 - Track Package - G0628
Yes, behind the black Synch module.
Condor1970 -
I think I’m getting this right from reading this thread and others. So on a 19 GT base I would need (in brief):
New “4 hole” dash panel/insert
Block middle vent
Gauge pack
Fish the lead from behind the sync/stereo/dash
Maybe at tune to activate one or both
Correct?
Thanks so much in advance!
bluestar
Illinois
bluestar
Illinois
Also, where are you guy's getting the trim for the gauges?
