Impact wrench and CF wheels
DaveJP
North Carolina
2019 GT350R
For you DIY people…Is it generally safe to use an impact wrench to remove lugs on the CF wheels?
galaxy
St Louis
'17 GT350
I wouldn’t use an impact wrench on any lug on any wheel I own, on or off…but that’s just me.
svttim
Wisconsin
2019 GT350R
I would be very careful putting lugs on. Off is no problem
Epiphany
Global
I like to disassemble things.
To be clear, it matters not whether the wheel is CF, aluminum, steel, etc, with respect to removing lug nuts. As for the wheel stud, it is in tension when torqued and as a result, stretched. So whether you remove the nut by hand or with an impact gun, you are simply allowing the stud to return to its static state, where no preload is applied. So in a "general" sense, it is safe.
That said, galaxy's opinion is one to live by in this regard. It wasn't asked but it should mentioned that there is an increase for the potential to cause damage if the fasteners are hot (as in open tracking and between sessions). While done in NASCAR for years, they also replace fasteners on a regular basis. For the typical Mustang owner, it is good practice to always allow the fasteners to be cool to the touch before removing and to do it by hand. And never torque while hot!
Sigma6
AZ
Jay
11’ GT500, 17’ 350
Zap em off when their cooler (I’d possible). Doesn’t need to be hours but not right after parking from a drive.. As for putting back on, I alway hand start the lugs so there’s no cross threading. Them chug chug lug. Drop it down (off the jack) and confirm by torque wrench.
svttim
Wisconsin
2019 GT350R
Good info as well. Also depends on the impact being used. If it cannot reach the torque value of the lug your safe.
JAJ
Vancouver BC
2016 GT350 Track Pack
Another thought - a lot of owners complain that impact wrenches damage the thin stainless steel cover that's on the lug nuts, stretching it and making it harder and harder to get a socket on.
Break the nut loose with a flex handle and finish tightening with a torque wrench, and you won't have this problem.
DaveJP
North Carolina
2019 GT350R
That’s exactly my concern….Will stay with the manual method.
Tomster
Beware of idiots
Tom
I Use a breaker bar to loosen them and then use a cordless impact wrench to loosen them as a time saving tool. I use care to not hit the cf wheel as the nut nears the end of the stud.
matthewr87
2018 GT350
I never had this issue with the stock nuts (because I always use a breaker bar and torque wrench) but I still couldn't resist buying those sweet, shiny and hefty Gorilla nuts to replace them, just in case.
Epiphany
Global
I do the exact same thing. I also take a quick look at the threads and hit them with a small wire brush (by hand, using a brush made for cleaning welds) if I see any debris in the threads or noticed if a given nut seemed to have more friction while coming off.
