sk47
- Nov 12, 2020
- North Eastern TN
- Jeff
- Chevy Silverado & Nissan Sentra SE
Hello; There is an issue with the context of your post. First, I am not disputing your experience but am throwing out an issue if you are correct.Dude my 18 pp1 with the 10r80 was ignition cutting like crazy on 94oct with 15-20% ethanol. Now i can only imagine how much harm you are doing to your engine if you run out of luck one day
The knock sensors must be working full time 24/7 and even if you don't hear it (as minimal it can be) it is bad for your piston ringland and your only looking for an engine failure eventually. And there is no excess in my reaction right here im only warning you that you should at the very least run 91 in this motor. Unlike previous generation this new one is pushing the limit of whats possible to run (compression wise) on street pump fuel. And your not getting 450 hp out of 87oct
The difference is so huge, that 87 octane you barely break tire loose, and on 94 you can do a 360 degree shifting from 1st to 2nd in drag mode if you keep it pinned.
Now you do what you want, its your car.
I did some checking when shopping for a GT about which octane was required. What i found at more than one dealer and by looking at gas caps on actual cars is that 87 octane is approved. I have also done some checking online. Others in this thread also have stated that 87 octane fuel is OK for the stock V8 Coyote engine. This has been verified by several in this very thread.
Thing is and will be that we cannot have faith in the specs put out by Ford if what you write is correct. I tend to go by the mfg. specs on most everything at least while under factory warranty. On some things for the total time i own a vehicle. If in fact you are correct that a Mustang GT needs at least 91 octane and should have 94 octanes, then the rest of Fords specs come into question.
I had a 1989 Ford F-150 pickup which was good on 87 octanes for a long time. I did start to notice a little ping when under a hard load. So, I began to run higher octane fuel in one tank and 87 octanes in the other tank. It had two fuel tanks. When doing a heavy haul or tow I used the higher octane fuel and things worked out fine until the truck weas totaled with 112,00 miles. So, I had an example of a vehicle needing a bit more octane under some conditions. Of course, that was over 30 years ago and the tech should be much better today. That truck had fuel injection. It may have had a build up of carbon on the inside of the combustion chamber after a few years. I drove it for over 12 years before getting into an accident.
I do wonder about how direct injection will work after many miles. In other types of FI the intake valves are washed by fuel so do not build up carbon deposits. Will it be that like the exhaust valves the intake valves can build up carbon deposits. That seems likely.
