I’d appreciate some code help please!
WItoTX
Houston
Kyle
thanks :) is it safe to flash the oem tune onto it with the wrench on the screen? I can do that easily enough, I didn’t want to just point the finger at the tune without trying some other basics :)
I have no idea, I would ask whoever sent me the tune.
MarkM
MarkM
NI
I contacted my tuner and they assured me returning to the stock map was ok under the circumstances. That done, my fault codes persist, anyone have any other ideas I can try?
MarkM
MarkM
NI
I’m getting nowhere with this, no one wants to take it on, I’m desperate!
Can you have a quick look please and give me an idea where I go from here? Do I have to buy a forscan token to take this further?
Any help appreciated
===PCM DTC P166A:00-6C===
Code: P166A - Restraints Deployment Communication Circuit
Status (-6C):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 179093275 s (Mon Jul 03 17:40:18 2023) - Event time
-TOTAL_DISTANCE: 23853 km - Total Distance
-FUELSYS: Open Loop - Fuel System Status (Open/Closed Loop)
-LOAD: 48.24 % - Calculated Load Value
-ECT: 42 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: 0.00 % - Long term fuel trim 1
-SHRTFT2: 0.00 % - Short term fuel trim 2
-LONGFT2: 0.00 % - Long term fuel trim 2
-RPM: 1283 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-SPARKADV: -10.50 ° - Spark Advance
-IAT: 25 °C - Intake Air Temperature
-MAF: 23.54 g/s - Mass Air Flow
-RUNTM: 5 s - Time Since Engine Start
-EVAP_PCT: 0.00 % - Commanded Evaporative Purge
-FLI: 29.80 % - Fuel Level
-BARO: 100.0 kPa - Barometric pressure
-VPWR: 14.55 V - Control Module Voltage
-TP_REL: 8.24 % - Relative Throttle Position
-TAC_PCT: 10.20 % - Commanded Throttle Actuator Control
-RPMDSD: 1250 1/min - Desired Idle Speed RPM
-O2S12: 1.63 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2)
-O2S22: 1.68 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2)
-TQ_CNTRL: Idle Speed Control - Torque Control Requested
-ENGOFF_TIMER: 213 s - Timer since Engine Off
-APP_FLT: No Fault - Accelerator Pedal Position Sensor Status
-CHT_F: No Fault - Cylinder Head Temperature Sensor Status
-CHTIL: Off - Cylinder Head Temperature Indicator Lamp
-ETC_TRIM_LRN: Yes - Throttle Angle Offset has Learned
-IAT_F: No Fault - Inlet Air Temperature Sensor Status
-MISFIRE: No - Engine Misfire currently detected
-TP_F: No Fault - Throttle Position Sensor Status
-FF_LRND: No - Inferred Flex Fuel Learned
-IMRC: Off - Intake Manifold Runner Control
-IMRC_F: No Fault - Intake Manifold Runner Control Fault
-MP_LRN: Yes - Misfire Profile Correction Learned
-MAF_F: No Fault - Mass Air Flow Sensor Status
-OTS_STAT: Enabled - One-Touch Start Status
-SMC_MON: Off - Starter Motor Control Output Detected
-STRT_RLY: Disabled - Starter Motor Relay Enable
-APP1: 0.82 V - Accelerator pedal position sensor 1
-APP2: 0.42 V - Accelerator pedal position sensor 2
-TP1: 4.14 V - Throttle Position Sensor 1
-TP2: 0.86 V - Throttle Position Sensor 2
-OSS_SRC: 0 1/min - Actual Output Shaft Speed
===END PCM DTC P166A:00-6C===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC None===
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===BCMB DTC None===
Module: Body Control Module B
===END BCMB DTC None===
===FCIM DTC None===
Module: Front Controls Interface Module
===END FCIM DTC None===
===DSP DTC None===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===SCME DTC None===
Module: Front Seat Climate Control Module
===END SCME DTC None===
DonnieO
Donnie
2017 mustang gt cs
Have you checked for a water leak in your floors? Ecu could have moisture in it.
Here is another option.
|Code P166A Ford Tech Notes
Some 2013 Fusion and MKZ vehicles may exhibit an illuminated wrench light with DTC P166A stored in the Powertrain Control Module (PCM), or the memory seat recall function may be inoperative during passive entry. Reprogram the Body Control Module (BCM) to the latest calibration
Not sure if this video is even close but anything is worth a try. At the end it mentions airbag reset
MarkM
MarkM
NI
thanks Donnie, I’ve had a look at all the modules and no sign of moisture anywhere :(
Apart from the occasional wash it lives inside and doesn’t get used in all weathers so that was always a long shot unfortunately, I had to check though.
Airbag module shows no faults but I’ll certainly give it a go :thumbsup:
MarkM
MarkM
NI
Can anyone point me to the locations of BCM-F and BCM-C please? Are they connectors on the BCM?
MarkM
MarkM
NI
Someone must be able to help before I have to burn it for the insurance lol
MarkM
MarkM
NI
Anyone? I’m getting nowhere with this and no one wants to help :(
fmc_smt
Cottonwood , Arizona
Those are connector at the BCM
MarkM
MarkM
NI
fmc_smt
Thank you, mine aren’t labelled, would you happen to know which plug is which?
I will be back to work in the AM then I can pull it up .
MarkM
MarkM
NI
