I’d appreciate some code help please!
fmc_smt
Cottonwood , Arizona
MarkM
MarkM
NI
Mark
Here you go .
Thank you so much, I have pin tests to do between plugs so hopefully I can figure out what’s happened :like:
MarkM
MarkM
NI
Mark
7 weeks on from the initial problem, 3 different people looking at it, damage done by one and paint needed, I’m no further on, still the same problem, I think it needs burnt, no one can help me, I’m so frustrated :(
Traffic22
SF Bay Area
Chuck
2018 F-150 Raptor, 2011 Ford CV Lemons Race Car
I know you said in an earlier post your local dealer is a nightmare, but if you haven’t done so already (didn’t see an earlier post mentioning it) it might be time to flash it back to stock and drop it at a dealer. (Even if you have to go to another town to find a competent one.)
Feel bad for you man, 7 weeks is a long time to be searching for a mystery problem.
MarkM
MarkM
NI
Mark
thanks :) I flashed it back to stock early on, a retired Ford engineer who loves this kind of thing is one of the ones that had a look, he undated software in all the modules from TSBs and is seeking advice within the company, I just can’t take it to a Ford dealer, none here are competent/willing to do what I ask……actually find the problem without just throwing parts at it.
I’m going to try an auto electrician, there has to be a wiring fault somewhere, all pin tests from Fords workshop manual check out ok however, but the fact I was sideways when it happened can’t be a coincidence, something is rubbed, pulled etc.
KilgoreLSU
Baton Rouge
Brian
2023 Mach 1, Ford Transit 250, BMW X5, 2000 Miata
Do you know anyone with the same vehicle? Swap ECM and see if it's the issue? I had VW Jetta, NEW, and it was throwing codes.. They had the car for a month and replaced the wiring harness, throttle sensor, etc.. and as a last resort changed ECM.. and it was the problem.
MarkM
MarkM
NI
Mark
Unfortunately I don’t, good idea though!
