Hurt Motor
JackBauer
Arlington, TX
2015 Magnetic base GT 6SP
sounds like the headgaskets are busted or you had head lift. engine would idle funny if u were running low compression on 1 or more cyls, and it'd be blowing both white and blueish smoke if you fried the pistons/rings.
but damn does it sound nice at high rpm.
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
just watched the video. im betting you pushed the head up. 18psi on a stock block is quite a bit.
olaosunt
Indiana
So with a busted head gasket do you just replace and go or does the block need to be re decked ?
Adaraas
Central FL
16 Premium GT, 17 Laramie Cummins
if it pushed the gasket you'd just replace it.
e: the gasket not the block:headbonk:
olaosunt
Indiana
Really ?
I get the block won't need to replaced but my engine builder said the surface of the where the gasket sits (both block and heads) may be have become uneven .
You could just keep blowing head gaskets if it is , unless you re deck it ?
Tommy V
Brookly park Md
Tommy
The deck should be checked and the heads should be magnafluxed to check for cracks anytime a head gasket is cracked/blown or overheated.
jhatley7
jhatley7
2016 White GT PP, 2022 F350
Update, didn't get to start the motor pull yet. Did get the new short block ordered along with an Armageddon twin kit. :headbang:
Phoenix
Central Texas
I'll take your old short block off your hands lol
jhatley7
jhatley7
Lol i'm thinking about possibly finding a foxbody to put it in. But open to all offers.:D
Phoenix
Central Texas
$free.50
Nah jk. I kind of want to build a motor but I'm not sure I ant to put it in an S550 now
Pro tip: look for an SN-95 or new edge car.
jhatley7
jhatley7
$free.50
Any particular reason to look at those? I was thinking a little older.
SoCalTim
CA
Tim
Sold : 15 GT
Armageddon twin kit....I was looking at that the other day, looks like a sweet set up!
How did you spec your kit?
jhatley7
jhatley7
Ceramic hot side, powder black cold and GTX3582R's.
MadCow
Bama
Civic
Suspension parts is likely the only advantage over a 79-93. And all those parts are cheap and can be swapped between both platforms. The 79-93 is lighter. The SN95 and New Edge are more readily available now. Just go with the one you like the best.
Phoenix
Central Texas
Little but longer wheelbase. HPP found this out on boosted ego's cars.
