HR361 Caliperfexion stud installation highlights
Tomster
Tomster
Beware of idiots
Tom
^^^^ And if I may say, the caliperfexion studs were designed for people in mind who do frequent brake jobs. I believe the idea was that the caliper bolt doesn't have to keep going in and out of an aluminum knuckle over and over again. The stud, once inserted, takes the wear and tear for frequent brake jobs due to heavy use (such as track events). If you don't find yourself in need of frequent brake pad replacements, this mod is probably not necessary.
yosv0610
Miami
www.instagram.com
Yosvaldy
2020 Ford Shelby GT350R, RAM 1500 TRX, Dodge Durango RT TnG
Yeah, I might never track my car as you do but as you said:
Why not get a set of caliperfexion studs and not worry about the bolts?
So, why do I have to worry? 🤣😉
Anyway, it won’t hurts for having them installed.
Epiphany
Global
I like to disassemble things.
I spoke to Yosvaldy today - great guy. He is changing to a ceramic pad I believe and doesn't track so I recommended he stay with the stock caliper bolts as his '20R has the unique, 1 year only, knuckle that requires a slightly different length stud. I would just be sure to clean the knuckle hole thoroughly and reuse the original bolts. I would wire brush the bolts and apply a few drops of blue/medium strength threadlocker and then torque to ~135 ft-lbs.
yosv0610
Miami
www.instagram.com
Yosvaldy
Yeah! I will buy all I need for this and I will get back to you if any doubts come out 😔
It was nice talking to you too!
Thanks. 💪🏻🐍😜
