How to Remove Window Sticker
NicksGTR
Ohio
Craig
2019 Ecoboost
Purchased an out of state 22 Mustang. It has the state inspection sticker in the lower left hand corner of windshield. The problem is it's over the inside window tint. Any chance I can remove this without damaging the tint?
Bronco2fan
Ft. Hood, Texas
2013 Taurus SHO LMS V11 Tune, 2006 F150 Harley-Davidson, 03 Mustang GT Conv.
I don't know of any state that allows tint that far down. AS1 line at top, yes.
Where was it purchased from?
I'd just use a razor blade and scrape it off.
NicksGTR
Ohio
Craig
2019 Ecoboost
Car came from Palm Beach Florida. Your probably right on the no tint, it's just when I run my finger along the inside of the A pillar there is a distinct edge between the black surround and clear glass. This is my first tinted car, so I thought I'd ask.
ray=out
SE MI
2015 Mustang GT PP
A fresh razor blade will make quick work of an inspection sticker. If you really have full windshield tint, you're gonna have to peel off the sticker by hand (in 1 million pieces) and use Goo-Gone or some other liquid adhesive remover to get rid of the residue.
ORRadtech
Atlanta, Georgia
Any tint on the windshield is aftermarket. Since it's a Florida car I wouldn't be surprised if a PO had it done. It's less for visible light blocking than it is for UV light. Living in Georgia we had my wife's windshield done. It has virtually no color but does help protect the interior from damage and reduces heat a little bit.
blankman
CNY
2023 GT
Try soaking the sticker itself with some warm water or soapy warm water then use an old plastic credit card or the like to remove it. Have done this before on my friends cars and it works pretty good. Sometimes there is residue left on the tint so just soak a microfiber in the soapy warm water again to remove the leftover adhesive. Hair dryers works also, just have it on low and keep it far enough away to not melt the adhesive on the tint. Little tougher but it still works as long as your careful.
BlkMach10510
2023 Mach 1 10R80
Use a handheld steamer to take off the sticker like this one:
NicksGTR
Ohio
Craig
2019 Ecoboost
BlkMach10510
2023 Mach 1 10R80
If the windshield is tinted, I would be afraid steam might lift the film?
Just go it long enough to get the sticker off. The steam took awhile to take off my tint, just focus on the sticker.
skiper
north carolina
15 gt
WD40 sprayed on a rag and placed on inspection sticker and let it soak for about 30 min. ill peal right off
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
Nope!!
NicksGTR
Ohio
Craig
2019 Ecoboost
Sticker is gone. Tried WD40 with limited success. My process was a hair dryer on gentle heat, a product from Turtle Wax called "Stuck Stuff" (comes in a spray bottle). Loosened an edge and gently pulled. Came off in pieces and the Stuck Stuff removed the residue, soap and water clean up.
Thanks for the replies!
