how often do you change brake fluid?
Zent
Minnesota
22 GT Premium
The manual says every 3 years with Motorcraft DOT-4 LV High Performance Motor Vehicle Brake Fluid
Though on my previous mustang (s197 GT) which I also bought new, I never changed the brake fluid and the brake pedal didnt start feeling squishy until 90k miles.
If anything with my 22 gt I feel like the brake pedal is TOO sensitive. I kinda want it the fluid to break down more lol
RowdyRam
SE TX
22 GT
Stick with the recommendation in the manual. I've gone (way) too long on a brake fluid change in another vehicle and ended up having brake issues. No fun.
Brake fluid absorbs water (hygroscopic? How do you spell that anyway?) and for that reason alone should be changed regularly.
nicksalvadore24
Boston, MA
Nick
2020 Mustang GT Premium PP1
Sensitive brake pedal = race car sh*t šŸ˜Ž part of the fun
WItoTX
Houston
Kyle
'17 GT350
If not tracking, follow the manual. Will you be fine if you go longer? Probably. But when some jackwagon slams on the brakes in front of you because a squirrel ran across the road, you will be real happy that you have good fluid.
You are protecting your self from others piss poor decisions. That alone would be why I would swap it.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
It's best to change the fluid as the manual says. Brake fluid and anti-freeze are glycol based. Glycol absorbs water over time, and breaks down to form acids. The acids cause corrosion. So, yes, changing brake fluid and anti-freeze coolant every 3 years is a good practice. šŸ‘
Zent
Zent
Minnesota
22 GT Premium
I have a brake fluid testing pen, but it looks with the way the brake fluid reservoir is designed they have the cap offset to where I can’t get it down to the fluid to test it. That sucks!
Bob Lob Law
Jeff
'22 GT 401A ESS A10
Not as often as I've been changing cars! LOL
Crew4991
Phoenix Arizona / Denver Colorado
Crew
Ford Mustang GT/CS, Dodge Viper SRT10
I agree that it is best to change according to the manual so every 3 years if you aren't tracking the car or regularly pushing it to its limits; however, I also think that timeframe can obviously depend on how you prefer the car to drive, how many miles it has, how many you miles you drive the car, and the climate you live in.
Personally I follow the manual at every 3 years I change the brake fluid but I agree with you OP, I too like the squishier feel of the brake when it is not as sensitive. I live in a drier climate with low humidity levels and daily drive the mustang roughly 5-6k miles a year (got other toys to drive as well) but the mustang only has 19k miles on it so far.
I definitely feel like I could get away with changing the brake fluid every 5 years based on my use case but I don't only because I am a fanatic about maintenance and want the car to last me a long time as my designated daily driver. You should base this assumption off your personal use case with your car. I wouldn't think you would have issues extending the timeframe a little, especially if it is more of a good weather toy for you.
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
Yes, if you're in a climate that's not very humid, you can probably go longer before flushing the fluid out. I have a fluid tester that checks moisture content in the fluid and I'll use it to determine when to replace mine.
Tycoon
PA
2018 Mustang GT Premium
I think hydrophilic
NightmareMoon
2016 Mustang GT PP w/ Voodoo
yeah that’s the master cylinder being oversized which you’re feeling.
Brake fluid is the last place you want old or worn components. You want worn rotors maybe, definitely not thin pads or old fluid. I’d be happy to sell you my old rotors as an upgrade if you like. ā€œPre-lightenedā€ special edition rotors with ā€œspeedā€ cracks.
Keeffa
australia
keith
ford mustang 2018 gt
I do it every 2 years. I've used the LV which is insanely expensive and the dot 4 and dot 4 works just fine.
