How do I know if my car has Traclok
Actormike
TN
2013 Ford Mustang V6
How do I know if my car has Traclok? My differential case is leaking so I'm going to go ahead and change out the gear to the 3.55 and rebuilding anything else in there. I have a 2012 V6
Here is what I ordered, did I miss anything?
3.55 Gear Kit- https://www.americanmuscle.com/355-g...-kit-1014.html
Traction Lok Rebuild Kit- https://www.americanmuscle.com/ford-88-traclok-kit.html
Rear Axle Bearing & Seal Kit- https://www.americanmuscle.com/frpp-...-kit-0514.html
Ford Performance Dif. Cover- https://www.americanmuscle.com/frpp-88-diff-cover.html
Actormike
TN
It won't let you delete the thread after posting it. maybe a mod can move it.
Earlsays
KATY, TX
2021 MUSTANG GT
EVERY Mustang from 2011 on up has a limited slip diff V6, V8, all of them
Fox-4
Just Lurking!
CA
Kelly
'02 Mustang GT, '16 Mustang Ecoboost
Earlsays
KATY, TX
2021 MUSTANG GT
I bought a brand new 2013 Mustang V6 with ABSOLUTELY NO OPTIONS AT ALL - it had a limited slip diff...with 2.73 gears
mustang_puppy
Santa Rosa, CA
Juan
2015 black Ecoboost fastback
Not sure if Ford still puts metal tags on rear end housings or uses the same number protocol like the older Mustangs but you can check the tag number and if it has an L in it, for example, a 3.00:1 rear end would have on the tag 3L00, then it is a Traction Lock.
smoke_wagon_6g
New York
18 GT
Do a burnout and count the stripes? Then you'll know if you have a LSD. That's the fun way and if you forget the stipes can remind you the next day.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
All S550s have limited slip diffs. The 15-17 GT PP and GT350 get a Torsen. All else get trak lock clutch pack. For 18, all GT350, GT PP and EB PP get the torsen regardless of transmission, else the clutch pack.
CoolRod
West Coast Florida
Jack the car up so both rear wheels are off the ground. Put transmission in neutral. Spin one rear tire and if the other rear tire rotates in the same direction, you have trak-lock. If it rotates in the opposite direction, you have an open diff.
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
^^^This
