Hot weather windshield "POP"?
robwlf
phila
rob
17 lightning blue pp LFP 670
ive never heard any of that .. and its been 100 plus the last 3 days here ..
Rickycardo
Rickycardo
Bolingbrook, Illinois
2015 GT auto
I tested it yesterday. I started the car, put the windows down but did not turn on the AC. I waited like 30 seconds and nothing happened. Then I put the car in gear and started to move forward, again without the AC and I heard the POP. It almost sounded like it was coming from the rear view mirror area. I stopped and examined everything but I don't see any changes or damage.
My next test is to put my dash cam in that spot and try recording it.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Body flexing under torque?
DanDglassman
NC
2015 GT Deep Impact Blue
I generally have one medium loud pop after engaging a/c. It has been 95-98 degrees here lately and it is like clockwork.
Rickycardo
Rickycardo
2015 GT auto
Alright one more test yesterday and this time nothing. No loud POP, just little popping noise interspersed over a few minutes. I think I'm just losing my mind. :headbonk::headbonk:
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
That pop could be the blend door inside the AC. My car doesn't do this and it's been 100* here lately and my car bakes in the sun all day and it's black so it gets really hot. I always have my AC on here except maybe in January sometimes lol. My wife's doesn't have this issue either.
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
When I was at Circuit of the Americas for a stop on the Hot Rod Power Tour, it got so hot at the track that our windshield literally cracked from the heat. I had the windows rolled up.
I'm glad you haven't experienced that issue OP, I didn't even know it was possible, but I found out the hard way.
Nick C.
shockme66
Easton PA
2015 Mustang GT 50th Annv. Magnetic
I get it too; it's the metal trim by the vents. It does it on a hot day when I first start up and have the ac on. If you press around that trim it re-seats it and stops doing it for a while.
EJS2016
Alpharetta, GA
Ed
2016 Shadow Black GT Premium, 6A, 3.55 / '08 GT
This phenomena is not unique to the S550.
My wife's 1 series convertible makes the same pop also.
It seems to come from somewhere in passenger side dash area.
The car was purchased in Florida and the pop used to be so loud it would make us jump.
BMW removed and reinstalled the dash at least twice, but could never determine a cause for this sound.
They added extra foam somewhere inside the dash and that helped, but did not completely solve the problem
The pop still occurs occasionally, but it's not nearly as loud as before.
I suspect it is a heat-related expansion/contraction of the plastic dash.
526 HRSE
California
2017 GT350 Grabber Blue
This is an old thread, but my windshield pops so loud it scares the hell out of me.
Elp_jc
None
On the GT350? First time I read about this issue, but seems to be on older cars. What year is yours? I only have 800+ miles on my Bullitt, but it's been over 100 since I bought it, and nothing like that. At least not yet. Ha ha. Had the squeaking dash, but it was the gauges. At least I thought so. After fixing them, heard a different squeaking noise but louder. It's the middle vents now. When I had the dash out to replace the gauge pod, they didn't make any sound. Not taking that thing off again, so will stick 2 pieces of rubber under them, and hopefully quiet them. By the way, the noise seemed to be coming from the windshield or rear-view mirror, but it was the vents. But no popping noise. I wouldn't like that. Doesn't sound normal.
526 HRSE
California
It's loud. It's happens about 10 seconds after you sit in car - while still parked. My wifes Mercedes doesn't it also, but not to this extent. I think it was 106 here today, but it happens in the 90's as well.
Bikeman315
Myrtle Beach, SC
Ira
Sounds like you are heading to your dealer or a top notch glass shop.
https://www.yourmechanic.com/question/windshield-is-making-a-popping-noise
This is from an Infiniti forum
I had the same issue...I just sprayed some silicon on the windshield by the cowl and let it run down and soak in between the cowl and the glass. After a few minutes I wiped the spray off the windshield and I haven't had the sound since.
