High boost readings
Stangmang
Stangmang
Massachusetts
James
2015 GT Mustang
You need the intake manifold, LT headers, the bap and the 52s. Now you’re car can hit a max power of 650wheel. After that if you wanted more you will need larger injectors
Thank you for clarifying.
illtal
Already did but I was intregerd to get others opinions after my initial question about the dyno chart. I think he was mainly saying the car would handle up to 650hp with the simple addition of a bap on 52lb injectors. I don't think it should make any extra hp nor should it require a tune with a bap. Correct me if I'm wrong, I'm still learning.
You will need a tune if you change any component that changes the airflow (More not less) into the engine, and fueling (ie; injectors, manifold). If you only added a bap you probably wouldn't need a tune. If you injectors and add more boost yes sir you will need a tune. As @Jackson1320 said you will need a few more components to make it happen.
