High boost Gen2 and E85
sloride
ohio
2016 GT
What have you been getting away with on plenty of fuel delivery and E85?? Currently 4.0 pulley P1X. About 14/15ish psi 7600rpm. Have a new block, forged components, supports, and cams ready to be put together. Car runs amazing now. Would you send a 3.70 pulley to maybe 17ish and see if it the stock configuration holds for the summer?? 😬
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
I've been running my car at 16 psi for a while now and it's been holding up. Well over 30 hits at that setting. Realistically it can hold that as long as you are good with maintenance and don't let the car get too hot (don't do back to back to back hits).
It's even seen 19-20 psi before, but only a few times. These motors can hold a ton of power, especially in short bursts.
FastCarFanBoy
2013 GB GT
My D1SC gen1 was on 16psi and held up just fine until the crank snout snapped off. The internals looked good though. If the fueling and tune are right you should be fine.
sloride
ohio
2016 GT
Nice! Thanks for the replies.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Stage 2 I assume? I would roll with the 3.7 no problem
sloride
ohio
2016 GT
How many miles did you get out before the snap? I think I’m going to try and leave my tensioner on the loose side and play around with almost verge of belt slip for shits and giggles
sloride
ohio
2016 GT
Was looking back on your accomplishments on the P1sc. 9.0.. 150. Crazy. How much boost, pulley size, and rpm got you there?
Jackson1320
California
Jaxson
2015 mustang gt
On a 3.7 you will push the procharger beyond the recommended rpm limits. Not by much so you will probably be fine but I would not go much farther. If you don’t blow your shortblock you can sell it to get some of your money back from building a new one. Also if It does blow you are almost 100% going to need to repair or replace one or both heads. Keep that in mind
sloride
ohio
2016 GT
Yeah I don’t spin my engine that high. 7500 so only about 1500rpm over blower speed recommend. More and likely just 7000 until I get my other motor built as to hopefully not blow it up🤣
FastCarFanBoy
2013 GB GT
I put about 25k on the blower before I sold it in sept. The crank snapped on the new owner. He recently put OPG's in it and switched to the ARP crank saver stud setup. Everything was installed by a Ford tech so I assume it was done correctly.
sloride
ohio
2016 GT
The crank snapped with the ARP crank saver stud??
Gregory347
LI, NY
Greg
2019 GT A10 PP1, 1987 Buick Grand National, 1985 Mustang
Seems like some important facts were left out in your earlier snapped crank story...
