Hey Process (and other E85 15's)
Process
Pittsburgh, PA
2016 Porsche 911 Turbo S & 2016 Shelby GT350R
I get about 250 a tank now. I bet at e85 flow rate your can almost WATCH the fuel needle drop under WOT lol
Tapatalk spelling errors inside!
Closest station to me is 13 miles, so figure I lose about 26 miles per fill up.
It's still worth it to me, E85 gives you a massive safety net for the power it gives you.
I'm getting about 10.4 mpg average right now.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Do you have injectors?
You need 47's n/a.
If you have a power adder you need id1000 or equivalent.
Process
Pittsburgh, PA
You need 47's n/a.
definite good advice, and with a powder adder, you'll also need a 22v BAP or a return fuel setup depending on how much power you aim to push.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
You guys should also consider an e85 mix. I've used mixes of 50/50 and 33/66 of e85 to 93 in a 4 cylinder turbo car with great success. These mixes give you the best of both worlds, the cooling and knock protection of e85 and you still get the lubrication of 93.
I would pull up to the pump and pump say 3 gallons of e85 and 6 gallons of 93 for a 33/66 mix ratio and then let it mix in the tank, sometimes just giving the car a few hard stops to help mixing.
Engine was a 2.3l at 26psi and no knock with this amount of e85.
04SloSnake
Boost Addict
Japan / Germany
R34 Skyline
E85 FTW. Always wanted to run it on my Cobra but never got a chance before I had to sell.
04SloSnake
Boost Addict
Japan / Germany
R34 Skyline
MS3? MAP is having great success with an E30 tune for the EB right now.
gqneon
gqneon
Westfield, IN
18 GT PP / Manual
You need 47's n/a.
Yup, I've got ID1000's and a JMS FuelMax already installed. I literally would have to go to the trunk and flip a switch to 22v to run E85 or a mix of pump gas and E85.
That mix idea is very cool. I guess even an 80/20 mix would be a huge step up in knock resistance and wouldn't require the massive flow increase. I'd take a range hit for mileage but not nearly as bad as 100% E85.
I don't want to hit the bleeding edge of power, just want zero detonation and say a solid 18-20 degrees of timing to redline. With torco and 93, my car is dropping to 14-15 degrees at redline. Without torco it's dropping as low as 12.5-14 at redline depending on gear/load.
I call that shitty.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Yeah, it was an MS3, 26psi of boost and 21 deg of timing at 6500rpm. Had to drop mix to 33/66 because I was out of injector, but still no knock. Some guys are running 25/75 e85 to 93 and have no knock problems.
When I finally get to put a blower on my Stang I'm going 50/50 for sure.
There are actually a few engineering studies of the effect of e85 mixes, I'll post them up later if the fuel geeks want to read then. Basically you get nearly all the benefits of e85 around the 50/50 mark. The incremental improvements from there on are smaller.
emh87
Akron, OH United States
2015 Black Mustang GT Premium 6MT
Do you need any special tuning to run a 50/50 mixture?
gqneon
gqneon
Westfield, IN
18 GT PP / Manual
Process, how can I find and email Eric Brooks? I couldn't find your original post about him.
I want detonation potential gone, and will pay him to get me there. With 20 degrees to redline I would have all the power I have been seeking with all this trial and error without the knock concerns.
esacteksab
CO & KS
2015 Mustang GT
http://www.brooksspeed.com/
gqneon
gqneon
Westfield, IN
18 GT PP / Manual
That was entirely too simple. Thanks! I sent him an email.
Phils15GT
Albany, NY
Post up when you hear back. I would like to switch to E85 and drop a pulley size. There are a few corn pumps around my house so it wouldn't be too difficult to fill up with that stuff.
esacteksab
CO & KS
2015 Mustang GT
No worries. I picked up my HPTuners and base 91 tune from him through his site. He's very prompt to respond. I've been too busy to do anything with the car though. I'm 2 blocks from an E85 pump so once the car gets boosted, an E85 tune will exist.
gqneon
gqneon
Westfield, IN
18 GT PP / Manual
I have an SCT X4, but it takes me 7.5 minutes to flash from one tune back to stock then another 7.5 minutes to flash to a different custom tune. I never had to flash back to stock with BAMA, but every Lund tune requires me to flash back to stock then to another tune. Maybe HP tuners would be a good replacement, but u already spent $400 on this one, even if it's shit slow.
