mustang_guy
- Jun 29, 2015
- United States
- it has an engine!
I know it does the same things as the test tube. But the idea of putting in whatever ethanol and not worring if itll blow it up as you go wide open without learning is neatBecause it won't work with the Mustang or the Tricor PCM. It will tell you the ethanol content but it cannot be used as a sensor to trigger a stoich and timing change. It just accomplishes the same thing as the test tubes.
The Ford PCM's in the F150 strategy have the ability to adjust after a short learning mode from the factory widebands to average timing and stoich based on ethanol content. This is a much more efficient process as you are not relying on an external sensor that could malfunction.
All we need to have is the strategy enabled for it to work on a Mustang.
