Help. Rear windows won’t go up.
01Romanss
Georgia
2019 Mustang GT Convertible 6 Speed PP1
2019 GT vert. 32k miles. Front windows go up. Rears do nothing. Any advice? Thanks.
MiamiGT350
S. Florida
I would check fuses and check the plugs on the back side of the switches.
Are there window up/down switches in there rear, or is it just the front driver's side where you can roll them up/down?
Johnnybee
Canada
2018 convertible
I’d expect that they’re on the same fuse as the fronts. If you can pull the switches out, check for power into the switch. If there is is power in, check for power out. I suspect it’s power in that is your problem, since neither are working. I don’t know if this circuit goes through a body control module after the switch or not. Maybe someone else can chime in.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
I have seen on some cars that the back windows are blocked from operating if the top is not all the way down or all the way up. Not sure if the mustang works the same way, but maybe check that.
01Romanss
Georgia
Thanks for all the responses. I found that I didn’t secure the top all of the way.
