BmacIL
Enginerd
- Sep 21, 2014
- Naperville, IL
- 2015 Guard GT Base, M/T
- Vehicle Showcase
- 1
I would get dampers from Levittown Ford or Whitebear Lake Ford automation stores. Levittown has a forum section here and they can prepare an invoice with everything you need.Ok thanks all. Here's the compiled list so far.
Must Buys
Should I Buy?
- CB005
- Ford Racing Strut/Cowl Brace
- SP082/089 or SP080
- Steeda Rear Shock Mounts
Questions
- Vert Links
- CB006/007
- Sway Bars
And out of all of these which do you guys think are the least important. I'm at around $1500.
- PP dampers on the must buy list I believe. Anyone have a link to those? Couldn't find just the dampers?
- Is SP080 the same as 082/089 just combined?
- Which vert links?
- Which sway bars?
- How much is car lowered by with the 82/89?
- This affects powertrain warranty right?
SP080 = SP081 fronts, SP082 rears. SP081 drops the front 1.2". SP089 drop the front ~0.8". The SP082 rears lower 0.5". The 081 and 089 are the same spring rates. This isn't enough lowering to cause daily use problems. My car is lowered nearly the exact same amount and I have no issues and it's daily driven (even in the winter).
This does not at all affect powertrain warranty. It would only affect the warranty of the suspension components you're replacing.
I would not do the vertical links, sway bars or front chassis braces (CB006/7) for what you're looking for, at least not now. Do these: CB005 + SP089/SP082 + PP dampers + Steeda billet mounts + FRPP strut tower kit. That's right at about $1200. You will really enjoy it.
