Help! 2020 Hellion Sleeper Install
Bulutt
2019 Bullitt
Just a general question about this type of installation, with the turbos so far from the intake, how is there not massive turbo lag?
myfast70
Az
Mustang
The pipes are as far as you think. They are also 2.5" so it helps keep the velocity up from the turbo to the IC. I'd say the pipes from the turbo to the IC are in the 24"-30" range so really not a whole lot more than other installations. The other thing to note is that the hotside is very short which helps the turbos react quicker thus negating "lag" a bit too
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
Just kind of mocked up for now. One of the pieces of threaded rod was too short and I’m waiting for the mandrel from my IW balancer from TKM to finish the pump. Still not sure how your supposed to connect this lower radiator hose though. It appears that the check valve just kind of floats out there rather than being secured to the plate now.
myfast70
Az
Mustang
Tough to tell from pic but is the hose outlet pointed right at that spacer or is there at least a little room to slip a hose on? Or is that what you mean by not sure how to get the hose on? On the previous plate you would cut the rad hose, insert a piece to reclock it and that was it or that's how I did the installs anyway. Here are some pics
bankyf
2022 GT500 CFTP
There is room to slip the hose on. I believe the new plate clearance is roughly the same in that aspect. The hose modification is where I struggle. While your pics make sense, that’s not at all what the instructions describe, nor did it come with enough parts. Did you come up with your own couplers? My kit only has one and I don’t see any way that’s going to work.
myfast70
Az
Mustang
Yes, I didn't like just the one so on the installs I've done I did it the way you see in my pics. I fab a lot of stuff so I tend to have lots of stainless tube around and made my own. It's much easier to do multiple pieces like I did.
Once you work thru it all it really is a great kit. Last one I did was on a 2019 A10 car that made 723rwhp on our $hit 91 here in AZ.
bankyf
2022 GT500 CFTP
Do you recall that hose size? I guess I need to order some couplers and maybe an additional 90.
wingnutt
@FL410
michael
350R Procharged w/P1X
subscribed for no apparent future reason 😬
bankyf
2022 GT500 CFTP
Progress, Lol. Every time I work on it I realize that there are more parts I need to do something different or better.
Cordero1
Kansas
Vic
2021 Mustang
If you did have to add your own 1.5" ss pipe, could you post up pics & measurements when you get time please. So we know what's missing
