Turbong
I noticed I am down to minimum from max but this has been over the course of ownership since I got it new. Not sure if I should be concerned being a closed system.
But, but this only happens to modified people. Jokes aside you made the right decision congrats. What was wrong with the block, walls, cracked? BTW trading for another Ford is a bad idea if you don't want problems have you seen the issues forum section? Endless threads of AC problems, drive line issues, transmission issues, Coyotes issues\failures and ticks and people going through lemon laws. Use good judgement again lol.Update: just got a call from dealer, it was not just the head gasket and Ford approved for a new long block. My car has always been stock and never tuned, thank God for warranty......
So, have you taken the poll and told us which cylinder the problem originated in?Update: just got a call from dealer, it was not just the head gasket and Ford approved for a new long block. My car has always been stock and never tuned, thank God for warranty......
Ya but it was weird when I talk to the advisor because the main one I was working with is on vacation. But basically they were saying cylinders 2&3.So, have you taken the poll and told us which cylinder the problem originated in?
this was January, any update? frankly trying to search maverick and ford doesnt work too well.I have several connections at Ford, in both Dearborn and Cleveland. It's nothing that's been published yet, but I'm sure it will as some point soon. If I could send some pics without getting anyone in trouble, I would but I don't want to risk someone's job for that. I will say that the rods are going to be different, the oiling system, cylinder head, and some other minor changes, like the intake manifold.
Frankly, I wouldn't be suprised if many ecobooms were caused by the LPFS failure, combined with aggressive/spirited driving...from my own experience, you can drive quite a while on failed LPFS sensor without the PCM throwing a code!this was January, any update? frankly trying to search maverick and ford doesnt work too well.
Ford has not acknowledged any issues with the sensor everyone is replacing. As far as I know, Ford is still installing the same sensor in the 2018-2019 models it was using for the 2015s. As far as I know no one actually fully understand the mechanism by which these failed/malfunctioning sensors can cause engine damage. The original claim comes from a tuning vendor whose customers have experienced a high number of engine failures.When did Ford become aware of the sensor issue ..?
Agree with above 100% as not only fact about that sensor and NO official statement from Ford - but that folks are just hog wild replacing it due to a vendor’s FB statement.Ford has not acknowledged any issues with the sensor everyone is replacing. As far as I know, Ford is still installing the same sensor in the 2018-2019 models it was using for the 2015s. As far as I know no one actually fully understand the mechanism by which these failed/malfunctioning sensors can cause engine damage. The original claim comes from a tuning vendor whose customers have experienced a high number of engine failures.
Some of us (in the minority) recommend leaving well enough alone unless you actually have a problem, especially if your car is still under warranty. Those recommending replacement say a failed sensor can lead to an engine failure, and since it's an inexpensive part and an easy job replacement is cheap "insurance."
I love that CJ's is selling this part to replace a "faulty" Ford OE part, yet in it's marketing material it claims this replacement part:for what its worth,, CJ Pony references the possible issue with the sensor as well..
https://www.cjponyparts.com/ford-lo...r-motorcraft-ecoboost-2015-2019/p/BU5Z9F972B/
I read through this page months ago when this issue was first bandied about here at Mustang6g. I didn't read anything there that explains the mechanism whereby a faulty sensor can cause catastrophic engine failure. Further, I lost confidence in the expertise of whoever wrote this when I read this line:Meets strict Ford OE quality, performance and durability
This is a direct-injected engine. The fuel and air mixes in the cylinder, not in the fuel rail.The fuel rail is where intake air and fuel are combined prior to being injected into your pony’s engine's cylinders.
Neither designs have air in the fuel rail.This is a direct-injected engine. The fuel and air mixes in the cylinder, not in the fuel rail.
And yet, if you walk into your Ford dealer, and request that part at the parts counter, you get the revised part. Imagine that I experienced this failure, on the stock tune. The dealer I took it do couldn't diagnose the problem ,since I caught it before the PCM threw any codes (they were more concerned with being able to bill Ford for warranty work...). They changed my plugs, and that did nothing (the PCM did note misfires across all cylinders...). I changed it, and it solved everything!Ford has not acknowledged any issues with the sensor everyone is replacing. As far as I know, Ford is still installing the same sensor in the 2018-2019 models it was using for the 2015s. As far as I know no one actually fully understand the mechanism by which these failed/malfunctioning sensors can cause engine damage. The original claim comes from a tuning vendor whose customers have experienced a high number of engine failures.
