HALP! Strut Tower Brace No Go!
Matthewstorm
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Those Steeda motor mounts are going to add NVH into the car. What is acceptable is a matter of preference. If you want to run the strut bar slightly trimming the edges will give you sufficient clearance. If you're not comfortable using a grinding disc, any competent shop should be able to make the modification quickly and at a minimal cost.
I have a whipple and got the strut bar to fit with about 15 minutes of work.
What did you do to make it fit? That looks awful tight.
09jsw
East coast
2015 Guard PP GT
Do you have experience with these mounts, or are you just guessing?
I do and they do add some nvh. Some have had issues with false knock using them. It will also change the pinion angle of the ds so that’s something to think about.
I removed them for stock when I added the blower.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
The studs are long enough why not add a spacer?
Tukman
Mission BC Canada
Pete
2020 pp2 Roush stage 2 Mustang GT/ 2019 Bullitt
Most people with SC use spacers on the strut brace. I saw someone on the forum used and sells spacers but I don’t know the name
Mantis
Valencia, PA
2015 Mustang GT PP
With spacers is there still enough hood clearance with the stock hood. A concern would be sufficient clearance between the brace and the SC for engine flex under hard acceleration.
Wolvee
Williamsburg
2021 Shelby GT500
I fit the tall Boss manifold under the Strut bar with Steeda MM's utilizing a 3/4" drop. BMR also makes a Engine side bracket that lets you lower the engine 1/2" and keep the stock MM's. I have both working together but mostly for clearance.
Also, Here is a nut that allows you to use a slightly bigger spacer on the Strut tower. EngiNerding rule of thumb for Fasteners is you only need as many threads engaged as the width of the fastener. That is the magic minimum to reach Tq specs most of the time.
BMW part # 51717895241
Wolvee
Williamsburg
2021 Shelby GT500
The factory strut bar is also stamped steel so if you're froggy enough, you can use a press to slightly compress the rolled edges to give slightly more clearance.
carguy231
SoCal
2017 Mustang GT
The other solution is the Steeda Extreme G-track brace [four point] that goes under the car. I didn't want to deal with the pinion angle, etc. of lowering the engine. And as a few mentioned only the PP cars come with the tower brace anyway. This is not an 'emergency' by any stretch of the imagination.
DougS550
Fishers, Indiana
Doug
Dealer is installing the Roush Phase II. I have the Performance Pack. That has the strut tower brace. The brace no longer fits because of the SC. I called Roush and they were NO Help. Unfreakingbelieveable.
Does anyone have a solution for a tower brace that will fit over the SC? Gotta solve this ASAP as I'm picking up the car next week.
Really appreciate the help.
If you lay the tower brace over the blower, will the hood close? If so buy or have made threaded spacer nuts, screw onto strut bolts to extend the reach and use bolts to secure it down. If the hood will not close, have a tower brace made to fit around the blower to where it will secure to the strut bolts. That is what I will do when I install my Whipple. Good luck
K4fxd
NKY
The strut to cowl brace is the important one.
Matthewstorm
Matthewstorm
NC
Matthew
Thanks. They're installing the Steeda motor mounts.
I would hope the hood closes.
crcpdx
Charlie
So reading through this, I just wanted to clarify on the 18-21 cars the brace will not fit unless you lower the motor. Spacers or shaving the brace will not work since the gen 3 hood is too low.
Matthewstorm
Matthewstorm
NC
Matthew
^This.
That's why they're installing the motor Mounts. It's also supposed to provide additional benefits.
DougS550
Fishers, Indiana
Doug
^This.
That's why they're instsing the motor Mounts. It's also supposed to provide additional benefits.
That is what I read. Usually lowering your engine can negatively affect the asymmetry of your drivetrain, oil pan height ETC, but it must be ok if Roush does it with their kits.
^This.
Matthewstorm
Matthewstorm
NC
Matthew
I haven't read anything negative about the motor Mounts. Many people do it. It's a very minimal change.
