GT500 - Power or Weight?
What would make for the best performing car? Power or Weight?
  • 650hp & 3,640lbs
    Votes: 50 37.9%
  • 675hp & 3,780lbs
    Votes: 10 7.6%
  • 700hp & 3,920lbs
    Votes: 16 12.1%
  • 725hp & 4,060lbs
    Votes: 32 24.2%
  • 750hp & 4,200lbs
    Votes: 13 9.8%
  • 775hp & 4,340lbs
    Votes: 3 2.3%
  • 800hp & 4,480lbs
    Votes: 8 6.1%
  • Total voters
    132
ttime500
seattle, wa
2016 Corvette Z06
Thank you. Most people just want a big number. A lot of people are short sighted when it comes to this stuff. Ford is trying to attract a different buyer now. One that wants a balanced car. There’s a reason why the GT350 is so wildly popular. And it’s far from the biggest horsepower number. Same with GT3, etc...
The lightest car is usually best but let’s be real it’s significantly more expensive to cut weight then add more power. And I’m sure we’ve seen roll races where hellcats beat Z06 so I can only picture the whining from the people that would want the lighter car. 700/3920 is going to give you a nice blend of not being too fat yet having the power. We’re at a point where technology has an ability to offset a lot of weight. Look at the ZL1 1LE, weighs about 3850, nearly as fast as Z06! Sometimes I think we get very caught up in weight numbers, I think if we went out drove these cars and guessed we would think they are much lighter. They’re 250 lb linebackers not 225 lb out of shape office guys!!
Trackaholic
2003 350Z, 2016 GT350, 2018 Pacifica Hybrid
In terms of ideal performance, the lightest option above would be best.
However, in terms of what is realistic, I think the two options bracketing 4000 lbs will the most likely actual numbers. I therefore voted for the 3920 lb option, which would be pretty sweet if Ford was able to achieve it.
I actually think the numbers will be more like 715 & 4000 lbs.
-T
Stuntman
SoCal
many
Agreed. More power also tends to make more heat, which requires bigger coolers, requires beefier components (drivetrain, suspension, etc..), all of this adds weight, which requiring bigger brakes, which adds more weight. It's a viscous cycle.
"Simplify, then add lightness"
- Colin Chapman.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere" - Colin Chapman
Epiphany
Global
I like to disassemble things.
Great post Stuntman.
1mic
2 mph so everybody sees u
Mountain View, CA
God bless America, all 8.4 liters -Randy Pobst
I lol'd at 3640lbs.
Anything under 3900lbs would be laughable. The 2018 is already 3900lbs. Even if that is a loaded model, this car will have a blower + supporting mods. That is probably going to weight another 100+lbs. And add what Stuntman said, bigger brakes, bigger wheels, etc.
Hack
Minneapolis
Mustang, Challenger
I lol'd at 3640lbs.
Everyone who doesn't have a Mustang says they are heavier than they really are.
Falc'man
Sydney
Falcon
If power-to-weight ratio was the be all and end all then I would disagree with those hints from members here indicating it will decimate the ZL1. There must be something besides these two numbers that will give it a clear advantage. That is where my curiousity lies. Judging by the video the car will get pumped guards, and wider rubber, but surely, there has to be some new tech beneath that no one's talking about.
I’m not saying that what BmacIL said is wrong, but as he have said before the numbers may have changed in he last months because of a lot of reasons.
If they change once can they change again? When they said "projected" it leaves the impression they're still working on it.
ttime500
seattle, wa
2016 Corvette Z06
That’s what I’m wondering too. If the power to weight ratio really is around 5.76 and the car is heavy as that would make it. There has to be some tricks and things going on that’s giving the impression too members/insiders to say it’s going to decimate the competition.
Farruko
Cali
Red GT 2016
If they already dropped the number from high 700’s to low 700’s is hard for them to go back up, since the most likely reason of the drop is durability/emissions/heat issues.
Or maybe, just maybe the reason is because of the DCT.
FishGeek
Boise, ID
Terry
'15 Mustang GT Premium - Guard Metallic
Wouldn't it be more appropriate to examine torque to weight ratios?
Regardless....it would also depend, I guess, on whether you were in a straightline drag race or a circuit like autocross. With turns I would definitely go with lighter weight for all the reasons already stated (braking, turning). In a drag race, from a standstill you're likely to have to contend with sitting there roasting the tires rather than getting down the track in a really light car with high torque/HP.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
It could be many reasons: DCT durability, axle durability, cooling, emissions. Bummer, though. As stated, at one point not very long ago there was an 8 in front...
Falc'man
Sydney
Falcon
Unless that low 700hp figure doesn't include the power from the electric motor it's basically a 2014 with way better handling and launch capabilities.
Nameless
México
Tedd
'13 GT
So... in other words “a Great Car”, right? Hahahaa
