Racerxray1
- Jan 23, 2019
- Rancho Cucamonga, CA
- Val
- 2019 Shelby GT350, 1965 Ford Mustang Fastback
I recently installed Trac Spec GT4 vents on the hood of my GT350. I wanted to cover the airbox and looked at several options. I settled on retrofitting the GT500 airbox, lid and fender seal on my car. I ordered the parts and waited for them to arrive. Once they showed up, I removed to the stock GT350 airbox and transferred a couple of grommets, a plug at the bottom, the horseshoe nuts and the intake nozzle (500 uses the same intake nozzle as the 350) from the stock air box to the 500 air box and it bolted right up. I used the hardware from the GT350 box because I wanted to use the studs from the 350 airbox so I could use the wire harness retainers. The 500 air box lid came with the necessary hardware and it all bolted right up. I did have to use weatherstripping on the air box and the lid to properly seal the intake tube. The intake tube is slightly larger on the 500 so the gap needs to be closed. The install looks like it came from the factory that way and now I have peace of mind that the filter will stay dry and is safe from moisture.
