gt350 transmission explosion / fire
Genxer
2015 Mustang GT / Perf pack / DIB
Not keeping an eye on the tach or just a flub? You never know.
Zitrosounds
Madison, AL
Harold
Honestly sounded like a Brain fart to me by the guy. A very expensive brain fart.
How do you flub a 130mph+ 4th gear run and down shift into lil ol' 3rd gear!?!?!
The engine must have made a scream heard around the world!!!!
BlkGT3
Hot Spot
13 GT86 Autox, 16 GT350 TP, 06 Civic Si TTD car
Seen it happen before. Newbie braking for a turn and hurry's the downshift or short shifting to 5th and doesn't apply enough pressure to get into the right gate. Either way it hurts. :( Porsche on the 997 GT3 cars designed the clutch to self destruct in that scenario saving the motor and transmission.
Peter
zzj
Boston
Zac
2017 GT350 H1828
Checked the plate and 100% sure the black one on the photo with Texas plate is a 2017 and judged by the seats it has the convenience package. The question is how did it catch on fire and will Ford replace him a new R too?
Zitrosounds
Madison, AL
Harold
Why would they replace the car for operator error???
Zitrosounds
Madison, AL
Harold
zzj
Boston
Zac
2017 GT350 H1828
Oh, I thought it's a different car since the original post said "Another one" up in smoke. My bad lol
Bingo13
Gary
'18 GT350R, '16 GT350 TRP, '18 GT PP2, '03 Cobra
Texas World Speedway this past weekend. Driver downshifted going from 4th to 3rd and transmission exploded. Made it to turn one corner worker where the fire extinguished. Coming off turn one at 130 mph, should have stayed in 4th.
There was absolutely no reason to make a shift where he did on that track. You go from 4th to 3rd before entering turn 2 on this car. And no reason to go into 5th down the straight. By the time you get to that point you are setting up for turn 1 and just go across the apron at full speed (doing about 142~144, R setup) then brake hard, wide turn, gas gas gas, then straight line brake and downshift before turning at 2.
Tomster
Beware of idiots
Tom
Here's what I'm calculating for speed in gears @ 8200 RPM:
GT350 with 305-35-19 rear tires:
1st: 55
2nd: 80
3rd: 111
4th: 144
5th: 179
6th: 285
GT350R with 315-30-19 rear tires:
1st: 53
2nd: 77
3rd: 107
4th: 139
5th: 173
6th: 275
Redline in 5th got me to 170. I didn't use 6th simply because it isn't a pulling gear, however, out of curiosity, I should have tried it.
The gears are stacked well in this car. You can figure engine RPM increase of around 1000 to 1500 per downshift per gear.
Those guys who blew their transmissions either made a mental error or it was a defect. I do believe when they hook it up for diagnostics, the computer will tell.
Essex Wire
LA
Shelby GT350 Tech Pkg
Where did OP get information that driver was shifting from 4th to 3rd? Does the driver say that on Facebook?
Essex Wire
LA
Also, assuming it was just tranny blowing, why the big fire? Trans fluid caught fire or did the pieces hit the oil lines/pan?
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
I was there this past weekend. Didn't see this live, but heard the scuttlebutt after the fact.
I always shift from 4th to 5th on the front straight, normally just before the start/finish line as I'm hitting the limits of 4th gear. Then scream in 5th gear until the turn in point. Downshift to 4th after coming off the banking.
Have to be very deliberate going from 4th to 5th to not catch 3rd by accident. I have nearly done that a few times and feather the clutch a bit to make sure its 5th and not 3rd cause it gets real exciting if you catch 3rd by mistake.
He left the track before we could talk to him, but maybe he caught 3rd gear by accident....
Zitrosounds
Madison, AL
Harold
Maybe! Either way you would have to really force it into gear because at that speed there is no way in hell it would have just dropped in. That moment of resistance is when the driver should have realized he was trying the wrong gear and should have applied a heavy dose of brakes then downshift. Or just ride the turn in 4th.
