Trackaholic
If the R springs are stiffer, they must also be shorter or the R would have a higher ride height (assuming the mounting positions are the same, which I believe is the case). Might be good to get a set of those first.
Most of the other mods seem to be pretty safe. Basically updating the same "standard" Mustang parts that everyone else is already upgrading.
I would probably only do the caster/camber plates if they were necessary to reach Ford's recommended track settings. Not sure if there is enough adjustment in the standard parts to hit those numbers though.
Looking forward to seeing the results!
-T
-T
