GT350 Intake Dyno..ENJOY!
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Just incase anyone wants to know Mmr seems to have the cheapest price for the intake and they have an adapter to use the stock throttle body. Just came across this
http://www.modularmotorsportsracing...page=product_info&cPath=28_29&products_id=836
That's a *great* price on the I/M.
Since some other folks have said they found the GT350 TB for <$120, does it make any sense to spend $70 and use what I'd assume was a much less optimal TB for the intake? I mean, $50 is $50, but in the grand scheme of spending ~$1200 all said and done, it's not all that significant.
I guess you also have to do something to adapt your intake, so $50-60 plus some additional hassle[?]
S550bluegt
Toronto, Ontario
Anthony
2015 mustang gt perf pkg m6
Considering the gt350 throttle body is so cheap and larger than the stock one I think it would be nonsense doing anything otherwise. I agree MaskedRacerX
rozay
South Florida, Broward
2015 PQ 5.0 MT
Is there a way to put the gt350 tb on the stock mani?
dev1360
STL
DIB 2016 S550
Not really a reason to. The stock one is more than sufficient.
S550bluegt
Toronto, Ontario
Anthony
From the measurements sandeale did on the bolt patterns it wouldn't make sense to put it on the stock manifold as the bolt pattern is wider so the plate you'd have to make to attach it would bottle neck the gt350 throttle body likely and make any possible gains almost unmeasurable.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Anybody know if the GT350 throttle body will fit a boss intake?
sandeale
North Carolina
2015 GT Premium PP
Unfortunately it wont, the bolt spacing is entirely different
dubster99
Nor*Cal
I was afraid of that. :(
moates88
New Windsor
2015 Mustang GT 6 speed
How big of a difference would there be if I kept the stock TB and used the adaptor instead of purchasing the 350 TB? And I currently have the JLT intake on my car, I would assume I need a bigger adapter if I used the 350 TB?
sandeale
North Carolina
2015 GT Premium PP
Using the stock tb, is pretty much negating the im swap, the gt350 tb is only 100 bucks more than the adapter (depending on where its acquired from)
As far as the intake, all you should need in order to use it with the gt350 tb is a straight 4inch coupler
moates88
New Windsor
That's what I figured, was just double checking. Thanks for the reply bro. Waiting on that tax return lol
