Gen 2 piston slap
scd603
Boston, MA
2017 GT350
My 2017's engine was replaced under warranty. New engine is definitely Gen 2, I checked sticker. It doesn't burn oil like the original but has some very noticeable piston slap until it warms up. Do others have Gen 2 piston slap? Would you push back on Ford?
matthewr87
2018 GT350
My 2018 has piston slap that is most noticeable when cold between 2000 and 3500 RPM. No big deal and engine runs well. I believe it is pretty common. There was an SSM to address it at some point (SSM 46173). Ford said it was harmless.
Deleted member 13861
Guest
19s and 20s got the Gen 2 unless Ford warranties earlier models then they get the newer version as well.
EFI
Masshole central
5.Br0
Forged pistons are always going to have a bit more noise than most other engines. Unless you're seeing scoring on the cylinder walls, I wouldn't worry about it. Piston slap is not detrimental to engine longevity just annoying.
scd603
scd603
Boston, MA
2017 GT350
That's what the told me too. Make sure the exhaust baffles are open!
I had slap with Gen 1. In addition to oil at 1qt/300mi, I did have scoring. Not so worried about being annoyed, just don't want issues down the road.
EFI
Masshole central
5.Br0
So that had more issues than just a simple piston slap. As I mentioned before, piston slap in of itself is mainly harmless and doesn't usually result in excessive oil consumption. The fact that you had that and scoring means your engine had other issues with the rings, piston skirts or bores.
If your current engine doesn't burn (as much) oil and if you check it regularly and doesn't have the scoring, I would say you'll probably have to learn to live with it.
scd603
scd603
Boston, MA
2017 GT350
Barely burning any oil. Maybe 1qt in 3.000 miles.
stanglife
Jeff
1993 Coyote Coupe
Likely fine. You'll notice it when the engine is cold with light pedal pressure. Don't try to make it happen all the time because while it's impossible to measure the long-term effects of this, common sense says it's not 100% ideal but rather part of the pros and cons of mechanical things. I try to apply medium throttle as to keep it under a little more load after I start driving...so I'm not bringing the RPMs up, I'm not going WOT and I'm not inducing cold piston slap. Doing the slight load (pressure=heat) gets heat in the pistons a little sooner and once they expand slightly in the bore, the noise should go away. Ford says if you can hear it a little when it's hot, that it's normal - and this has been my experience in previous performance cars.
If the sound does not change at all when warmed up, then worry.
Kachow
Georgia
2017 GT350
First thing I noticed about my 2017 when I bought it. Can hear it when its cold out. Noticeable around 2220 RPM on the dot. After researching it to hell, normal. These cars have a lot of...quirks.
