Gas smell inside car
joe603
ATL
Joe
2021 GT Premium PP
My wife has a superhuman sense of smell. Occasionally, she complains that my 21 GT has a gas smell. I don't smell anything...but I figured I'd ask to see what I should check. Only mods are the stereo and H-pipe. I need to check the clamps on the H-pipe, but that shouldn't smell like gas. And no, I haven't punctured my fuel tank...that would be pretty obvious for even me to smell.
NGOT8R
Adrian
2019 Bullitt
Are the windows up or down when she says she smells gas? The only time I smelled gas inside was when my line ruptured. The line is composed of a stainless steel and nylon (pressed onto
the SS). Mine ruptured right where the nylon line slipped over the SS.
I remember reading an article where a Ford employee had altered the flare on the line causing it to weaken in a fashion similar to what I experienced. It may have been on an Ecoboost, but I can’t remember for certain.
Click on post #4 in the link below to see the fuel mist coming from the the line, as well as hear it hissing.
https://www.mustang6g.com/forums/threads/2019-bullitt-fuel-line-leak.197116/
ORRadtech
Atlanta, Georgia
Pop the back seat base out and check around the pumps, check all the fuel lines around the tank, under the car and in the engine bay. Check lines key on/engine off so they're pressurized.
When does the smell happen? Meaning is it related to anything like a hard pull, a hard turn, a fillup?
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
Yep, pop the back seat and start there.
If you don't find anything there you can check the fuel line that runs up by the driver's side VC and firewall area.
And then of course, you can trace the lines under the car back to the tank.
If there is a leak. Even very small, you will smell it quite easily when you're on top of it.
Is it possible she's smelling exhaust?
joe603
joe603
ATL
Joe
2021 GT Premium PP
Good advise guys! I'll check out my pumps to see. She said that it hasn't smelled in a while, but it was there last weekend. No hard pulls...she was in the car. It sat for a few days.
NGOT8R
Adrian
2019 Bullitt
You said pumps, are you running dual pumps?
Did you do a cat delete? If so, that is usually where abnormal fuel odors will come into play (aside from leaking pumps, leaking fuel gaskets at tank and/or leaks at engine for fuel injectors or fuel psi regulator).
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
This was an issue with the early trucks, the fix was to tighten the spark plugs.
Mine just started getting the fuel smell and I also got a check engine light for evap tank filler seal code.
I'd check to see if you have that code pending. Hurts nothing to check spark plug torque.
joe603
joe603
ATL
Joe
2021 GT Premium PP
Very possible it's exhaust. I need to make sure my H-Pipe clamps are tight, it's been about 3 years since I installed them.
joe603
joe603
ATL
Joe
2021 GT Premium PP
No pumps, no cat delete...going to do ESS eventually, but other than H-pipe, no mods
North Carolina
Jim
2018 Mustang GT Premium
The one time I smelled gas in my car, I tried to squeeze a little extra in after the pumped clicked off. I know better, but there was a hurricane on the way
