SJulian10mm
- Jan 16, 2017
- Marysville, Jefferson
- Mustangless
I see Nor Cal, where? do you run Thill?Sounds good. Let us know how it goes.
Ill be at Thill on the 26th of April and again in early June. Anyhow, Diff bolts came in, went to ford yesterday and got new axle nuts and a tube of TA31. Also pickup some grommets, more blue Loctite, and 3 different sizes of wire loom. Looks like the kit will arrive mid next week.Thunderhill and Sonoma. Still trying to get to Laguna but timing never works out for me yet.
With the help of a good buddy who is extremely mechanically inclined we got my camber plates on, alignment done and rear diff cooler installed last weekend. It went fairly smoothly. I have an 18 and will point out the torx socket that came with the kit won’t work on an 18 as the bolt heads are torx plus. That slowed us down a little. My buddy cut the switch out of the wiring and we wired it to a hot ignition switched on souce so it’s hot and ready to go when the thermostat grounds at the desired setting.
Does anyone know on the thermostat dial provided with the kit which direction to turn the nob to get the lowest/highest temp setting?
