FRPP Handling Package installed and impressions
valentinoamoro
US
15 TY Mustang GT
I am considering wrapping this package into my upcoming special ordered GT/PP. I can get a killer deal being an employee.
In hindsight, if you had to do it all over again, would you do just springs and swaybars and square tire setup and get similar results? Seems like it'd be more cost effective.
Disclaimer - speaking more as an enthusiast/engineering background fellow and not from experience on this specific kit.
I would not change out the springs while keeper the stock dampers. The springs and dampers should always be paired to work together, or the bounce will get worse etc. This kit is the only one out there right now for the S550 GT (other than some early takes on Coil Overs) which is matched.
RouteAbel
2015 GT PP, Magnetic
Austin TX
That's what I did and I have no regrets on the kit.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Are the sway bars in this kit tubular (hollow) or solid and what size are they please?
Anyone know this and what size are the bars?
GTPaT
CA
2015 Mustang GT, 2003 Sequoia
Here you go. Mine was delivered on Friday. Haven't installed it yet. The bar does sound hollow when I hit it a couple of times with a flat head.
Rear 25.74mm
Front 37.84
Gibbo205
UK
Cheers buddy! :)
Stock I know is around 32mm and 22mm so a nice upgrade there.
Did you buy the complete kit? I am thinking this is the best move and if at a later date I want more adjustability or if the FRPP bars are solid I could always change them for the BMR ones, but I do like how the FRPP is one matched package.
Look forward to hearing your feedback on the package and the improvements over stock PP setup. :)
Stei3403
Detroit
2015 GT PP Oxford White
So my car already has Eibach lowering springs. Would this kit work well with those springs or is it absolutely necessary to use the Ford springs? I am considering just purchasing the Strut/Shock kit instead of the whole FRPP, and saving myself ~650 bucks. This, however, would lose me the upgraded sway bars that come in the kit, but I would still have the upgraded shocks and struts (and eibach springs). How much of a difference should I expect?
Old 5 Oh
Wilder, ID
David
2015 GT Premium AT
Buy and install the whole, balanced, engineered-to-be-a-kit package, and sell the Eibachs.
Alloy
S550 EB
As this kit is for the GT, purchasing it wouldn't make much since as the springs are for the GT as well as the shocks. Having a base Eco I could only benefit from the front and rear sway bars correct?
Kbreese
Long Island, NY
2012 Mustang GT Premium, Black/Saddle.
Does this kit do anything to reduce or eliminate wheel hop, or do you need other parts for that.
Budnr22
Northern VA
2016 GT350 - Oxford - Tech Pack
I think this is what I am doing - will likely keep my steed sways though - just install the matched struts, shocks and springs.
CrazedAntelope
San Jose, CA
Chad
Ecoboost Premium PP
This is somewhat true, but there are exceptions. People have been raving about Steeda Ultralite Linears + FRPP dampers.
Owning an ecoboost mustang, its sort of hard to not mix and match parts. This is my list of priorities when choosing suspension parts:
1. Spring rates should be paired for your car. Do not buy the complete FRPP kit and put the GT springs on your Ecoboost. The spring rates and overall ride height will be off.
2. Damping should be paired for your spring. The stock PP or nonPP dampers will not do you much good when paired with a stiffer aftermarket spring. In this case, it is better to go with an aftermarket damper (such as a FRPP damper), even if you aren't using the FRPP springs.
3. A swaybar is a swaybar. They are all adjustable anyways so they all will provide a range of torsional flex on the bar. There is a reason nobody sells ecoboost sways vs GT sways vs V6 sways. Any of them should be fair game. Its just a matter of quality of the bar or quality of mounting points you have to decide on.
derieuz
The Young Fella'
Southeast Michigan
2015 Mustang GT PP
The kit would still fit on the ecoboost, as far as the spring rates/damper rates go, They would feel a tad stiffer than what they would feel like in the GT. The main difference in the ecoboost is that your car is lighter by X amount of weight. It was designed for a car that weighs X+Y weight. So if you are using the set that was designed for the heavier car, it'll still be proportionately engineering, but it'll just be a more aggressive kit (in theory).
rvlyssup
Vag...Gun...Stang-NUT
Palmdale...The High Desert of SoCal.
Rand
Lotsa...
Who has the best deal on the FRPP strut/shocks? If I recall correctly, somebody was selling the kit for $500 on black friday.
Autonation Ford, White Bear Lake.
