Todd15Fastback
- Dec 10, 2013
- Atlanta, GA
- Todd
- 2015 Mustang GT PP Fastback
Go with the Steeda progressive springs, add the sway bars and their billet mounts and don't look backWOW...Thank you for posting this. Some VERY valuable pictures and insight to the suspension...The comparison photos are amazing. The sway bar looks identical except for an extra mounting hole which I am sure is what makes it stiffer. Also without knowing the valve'ing in the Strut I would swear they are the same just powder coated blue. What will be really telling is does it remove the bouncing.
However, the one time use for the bolts is something that if true we should all be looking at.
Can't wait to see more...THANK YOU AGAIN!!!!!!
Added thoughts...
The Steeda Sway Bars look MUCH thicker...anyone know the size of those compared to the FRPP? Also, Not sure looking at the Struts in the un-loaded position indicates drop. I BELIEVE it is the spring compression that will determine ride height. I am no suspension specialist, so maybe someone can chime in on this...I am TORN personally what to do to fix my bouncing suspension. I was leaning this way, up until this post...LOL!
The ride with these progressive springs is perfect. I swear it is. SC Pilot will agree, I believe.
