Front Splitter Extension Canards with Air Channels
tosha
Canada
Mustang GT PP1
The splitter extensions only extend in front of the front tires to reduce turbulence and has air channels to push air over the wheel wells. If you go to the zL1 add on web page look up GT 500 splitter fender extensions.
Yes, I know what they are. My question was what splitter do you have to go with them?
MAGS1
Somewhere in Middle America
2022 Mustang GT
tosha
Canada
Mustang GT PP1
It is an OEM GT Premium splitter.
Thank you, if you can share the pictures of end result once you have them installed, that would be awesome. They don't have good pictures there.
GrayMater22
GrayMater22
Sanford, FL
James
22 Mustang GT Premium
I will have some pics posted up by the end of the day tomorrow, adding 2 more fasteners, I want this rock solid over 100 mph. I will also provide some feedback at different speeds, as it was very hard to find info on this when I was researching. Most of my research was based on performance car aero from engineers and wind tunnel testing.
MrMike
US
MAGS1
2022 Mustang GT
I haven't seen these on an S550 yet. I wasn't sure where they attached but found this pic on Levittown's site:
There’s a video that Steeda did for the install. Looks pretty simple.
MAGS1
2022 Mustang GT
Here’s the Steeda video. They do the install on an S550
GrayMater22
GrayMater22
Sanford, FL
James
2016 Mustang GT PP w/ Voodoo
The OEM cars sometimes have air ‘curtain’ to direct airflow to the outside of the OEM tire packages. (18+ non PP1 cars have these, and 15-17 PP1 cars have em) They probably closed them on the 18+ PP1 cars because the wider front tires were too wide to benefit from air curtains in that location
Tire spats like that ZL1 part are used when you’re running wide front tires which stick out past the bodywork. The spats help in those cases.
If your tires are still well covered from front airflow by the fenders, im guessing you’d be better off with actual canards and not draggy spats.
The real win would be a splitter with a geometry to create downforce, such as diffusers, like the OEM Shelbys, and which is low to the ground and not up at the stock underbody height from the ground. The downside is low long splitters scrape on just about everything, so not fun on a daily driver., which is why the Shelbys splitters aren’t super long or low but include curved channels down there which act as diffusers to generate some downforce.
GrayMater22
GrayMater22
Sanford, FL
James
I run 275/35r20’s and these block my tires and wheel wells perfect, so far they seem to definitely add downforce, more than I expected. Don’t really want anymore downforce than this, just wanted to bring the nose down after the 60’. It definitely feels more stable over 45 mph and just plants harder after that.
MAGS1
2022 Mustang GT
FYI if anyone wants those S650 strakes, Tasca and Levittown have a better price than Steeda. Almost $50 less
GrayMater22
GrayMater22
Sanford, FL
James
Thanks, I think I am going to give them a try, for $100 they surely can’t hurt anything.
GrayMater22
GrayMater22
Sanford, FL
James
Here are the pics. After securing the remaining splitter/fender extension holes to the factory splitter with larger sheet metal screws and washers, I also applied 2 small felt pads at the top of each air channel where it is very close to to fender to protect any possible paint damage. Then I took a little trip on a nearby interstate and got up to speed 😎, as I stated previously you do begin to feel some downforce around 40mph and then it just progressively gets stronger, the real benefit was much better front end stabilization over 70mph. After that, I ran it thru my local soft touch car wash and inspected all hardware, everything stayed perfectly in place, seemed very solid 👍
