Forscan EQ
Earlsays
KATY, TX
2021 MUSTANG GT
I have been searching and searching, and I just cannot find which setting to change for the EQ bass roll off thing in the ACM - I tried looking in the “as built format” category, under ACM, and it says “EQ” with a value of 1
is that what I change? If not, trying to find the code to change…. Car is a base GT/small screen
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Here you go...
This has been discussed many times. To disable factory EQ you only change the first two hex numbers to zero. Leave all other digits alone. If you changed other bits, you should set them to what they used to be. Hopefully you wrote down the original settings.
727-01-02 - 00xx "Disables Factory EQ Processing" (don't mess with xx or change anything else)
Here is a spread sheet...
PICASSO
Millsboro, DE
2021 Mustang Mach 1 Fighter Jet Grey
Here you go...
I have a 2021 Mach 1 and I used Forscan to try and change ACM, My ACM already has 00xx. I have the 12 speaker B&O system. Is there a different way to change it on a 2021 model? Any help would be great. Thanks!!!!
PICASSO
Millsboro, DE
I have read that the B&O is already set flat, so no need to change anything.
Can you point me in the direction of where you got that info. I would hate to go through the trouble of installing all my new equipment if its going to sound lousy.
Cathul
Germany
Peter
Ford Mach-E
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
It was in the M6G forum somewhere, but I don’t remember where exactly. I think it was someone that swapped the B&O amp into the 9 speaker system so they could get the sub output.
PICASSO
Millsboro, DE
https://www.f150forum.com/f30/head-unit-measurments-forscan-changes-high-level-vs-low-level-467373/
Not specific to the B&O, but shows the Sony SYNC3 and base SYNC3 measurements.
Almost all SONY Sync3 EQ settings show a flat output. If you already have a "00xx" in the corresponding ACM setting, then you don't need to do anything. Same for "0( 4, 5, 6, 7, 8, 9, A, B )xx".
With these settings all equalizing, crossovers etc. are done in the SONY/B&O amplifier, not in the ACM.
Thanks so much!!!
MX5Racer
Saratoga Springs NY
www.rixclix.com
2016 GT Convertible
when i made the suggested changes in forscan to disable the eq, the door chimes and chirps became insanely loud. had to switch it back.
Seatbelt Reminder Chimes - Enable/Disable (turns off the
chime/sound, but does not change when the instrument cluster
light will illuminate)
IPC 720-01-01 : xxxx xx0x xxxx
Door Ajar Chimes IPC 720-01-02 : xx0x xxxx xxxx
rojizostang
San Atonio, TX
Rusty
2023 mustang gt
thanks
is there a way to turn off the chirp when switching channels on the radio?
MX5Racer
Saratoga Springs NY
www.rixclix.com
2016 GT Convertible
steathv
Lynchburg, VA
2022 California Special
You can go in the audio Settings on the in dash screen and cut the sound. Off when you change channels:
Jon 5.0 2015GT
New York
Jon
2015 Mustang GT Premium
Here you go...
Hi, I looked at the spread sheet and seen a couple of codes I’d like to change but they have a ? Mark instead of the number it can be. Do I just guess or randomly choose a number fro 0-9.
