Formula 1 talk.
sk47
North Eastern TN
Jeff
Hello; Some good points made in the last few posts and one spin. First the passing nod to F1 being green with the power units and battery packs is just that. The greater measure of horse power comes from the fossil fuel engine. Overall even the electric energy recovered is harvested from energy produced by the fossil fuel engines. I guess the portion of energy harvested during braking is energy which would otherwise be shed as friction heat from the brakes. Not clear to me how the extra weight and complexity of the battery-electric system yields a savings of fossil fuel to begin with. I do get the There is likely a term for such a pointless endeavor as the hybrid power packs in the ultimate race car. Enough on that.
The pitstops to refuel can be worked out if refueling is determined to be the way to go. To me as long as each team is equally affected the length of time is not a factor. If each team has to equally take 30 seconds or 45 seconds or one minute, then there is no penalty attached. So, fuel rigs can be made safer. I think in some of the endurance races the pit stops have to be some set minimum length of time which is more than plenty to do safe fueling.
The fuel saving in other race forms generally takes place on the track and not in the pits. There are ways to use less fuel while racing. We can discuss them if needed. Basically, fuel saved during track running translates to shorter refueling times during the last fuel stop. Takes less time to pump less fuel into the vehicle.
F1 fuels were at one time a witches brew of exotics. The race directors eventually put a stop to the exotic mixes and set a standard fuel. I think this is why a quart or so of fuel is needed to be left after qualifying and race end, so it can be tested. Ferrari had some very strong and expensive race fuels back in the day. Side note- Not that long ago Ferrari apparently was burning engine oil for extra power during races. The exhaust smoke gave them away I think.
Best i understand from reading decades ago the early F1 races were set at two hour limits and such has stuck. They also did not change tires in the early days. The tire bit has been changed as has most everything else. I have no issue with a two hour time limit, but if a change will result in finishing a race under green, then such is fine.
Drivers in endurance races or NASCAR races go much longer than two hours every year. Does not seem the F1 drivers are so puny as to need a two hour limit.
sk47
North Eastern TN
Jeff
Hello; The race had both fine moments and sad moments. Sad in the first lap when a MB punted the Ferrari. Not sure that all the blame should go to the MB driver (Russell) The Ferrari was well enough ahead to be sure but when he squirted to the left after nearly running into the back of the RB he left himself open. I was taught to be a defensive driver on street roads and by that I mean sometimes you do not make a move that leaves you exposed. The Ferrari might have stayed behind the RB a while longer and survived to race on.
What is the old saying? You cannot win a race on the first lap but you can sure lose it. That said I do not see a five second penalty as enough.
The fine moment was when the RB overcame a bad pit stop to come back and win. The team made a better call on the tires for on thing. The RB is just too fast. The drivers becoming self-appointed track limits monitors was cringeworthy but seems to be the norm anymore.
JohnnyGT
NoVA
'20 Mustang GT, '17 Expedition, '04 LS430
Way to wave that flag with such enthusiasm Tim Cook.
It was laughable. Zero expression, zero interest, the weakest attempt to move his arms: batteries overhead; like my on MBP.
Hello; Who is Tim Cook? More precisely, what has he to do with F1?
EDIT - I also noted the limp flag waving.
Nothing?
Apple doesn't sponsor any team if i recall. There could have been 1000s of better American's to wave that flag. You know, people that care at least a little about F1.
XeninWorX
Toronto
KC
2014 Mustang
$7M fine and 10% less aero testing. What a joke.
Bikeman315
Myrtle Beach, SC
Ira
Yup, just read about that. Are we surprised? :puke: Also did you see that Alonso’s penalty from Sunday was reversed?
I would say that F1 is turning into NASCAR but that would be unfair to NASCAR. :facepalm:
