Floating at 120mph plus
Bgrames
Kentucky
Brian
2017 mustang gt
I recently went to 20 inch wheels from the stock 18.8 I have 255’s on front and 305’s on the back the car seems to float at 120 mph any help with this would be appreciated
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Non performance pack GT? Lol it's just the dampers, they're soft for comfort. At high speeds they struggle to dampen the mass of the car fast enough for confidence. You also have a pretty extreme stagger going on there. I suspect that much unequal grip is going to amplify the problem significantly.
Another solution is to not drive double the speed limit.
FruityJudy
South Alabama
2018 Mustang GT A10
Along with the soft dampeners you also have raised your cars height which is allowing more air under the car. You may want to look at lowering springs and a nice functioning splitter.
Or you could never drive past the speed limit and live in a little bubble wrapped shell with no enjoyment or dopamine release.
Bgrames
Kentucky
Brian
2017 mustang gt
Thanks also I didn’t think about the fact that I had about 100 miles on the tires was wondering if that could contribute to this also
Bgrames
Kentucky
Brian
2017 mustang gt
Didn’t think about the height of the car that’s a great point I just looked at it lol thanks again
I Bleed Ford Blue
North East OHIO
Tire pressure will play into this also. I just recently had mine in for an oil change and they added air to my front tires and over inflated them. They put 40 lbs in them and they felt floaty at 60+ mph. I dropped the pressure back down to 32 and all is fine now.
HeelToeHero
Ontario
17 GT PP, 23 Elantra n-line
What's the final OD of the tire? I suspect you raised the ride height with the wheel change and more air is getting under the car.
Bikeman315
Myrtle Beach, SC
Ira
Question.......why so thin on the fronts?
Also , any suspension mods? If not it's time to start thinking of them.
