First Oil Change Coming Up
Rainier42
Bucks County, PA
2019 Performance Blue GT350R
Anyone know what the front floor jacking point for the 350 is? Need to crawl under to check things out for my first oil change (doing at 500 miles). Longer term will be purchasing a Quickjack to get all 4 wheels off the ground.
Also, is there anything special about the drain plug? Have heard it is not removed ... only turned counter clockwise 360 degrees.
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
I did my 1st oil change today, and the filter part was the only thing that wasn't neat or easy. I have investigated the options to lift the car and this was my best choice for my garage setup. I have installed the Steeda jack rails on the car, and those make getting the car up off of the ground a fairly easy task using 4 jack stands. A low profile jack is needed to get under the car. The difference with the jack rails is that the car gets raised side-to-side rather than front-to-rear.
Your other option is low profile race ramps, but the jacking rails will get he car higher off the ground.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
I wonder if my 56" maintenance race ramps will clear the splitter ? :shrug:
