Key qualifier right there . . .Why would anyone with any sense rev a cold engine to high revs?![]()
It could happen though. Come out on a cool day on your way to work or maybe after lunch, pull out onto the road, realize there is a car bearing down on you out of no where (perhaps he wasn't there when you started pulling out but changed lanes or something) You hit the throttle to make sure he didnt have to hit is brakes. Smile as you realize he never even had to touch the brakes.........cringe when you realize you just got into it real hard while it was still cold..... shat happens.Key qualifier right there . . .
Norm
Have you met....people?Why would anyone with any sense rev a cold engine to high revs?![]()
I realize that situations can and probably will crop up from time to time.It could happen though. Come out on a cool day on your way to work or maybe after lunch, pull out onto the road, realize there is a car bearing down on you out of no where (perhaps he wasn't there when you started pulling out but changed lanes or something) You hit the throttle to make sure he didnt have to hit is brakes. Smile as you realize he never even had to touch the brakes.........cringe when you realize you just got into it real hard while it was still cold..... shat happens.
Then these are every where:I thought it was just common sense to let things warm up, but then again these are human beings so any nonsense is possible.
That is missing the point. No, you don't need to let it idle for 10 minutes. What you should do, is let the engine drop from the initial higher idle speed (about 1250 rpm on the Mustang) down to the first 'warm' idle speed (about 1000 rpm) and then drive off. Accelerate moderately, and generally keep revs below 3000-3500 rpm until at operating temp. After the coolant is up at >190 and oil is well into the 'green'...rev away. 30 seconds isn't necessarily enough time at all temperatures and with all engines. It's not a bad guideline, and is WAY better than what I see many people do. I can't tell you how many folks I've seen start up the car and IMMEDIATELY throw into R or D. Poor engines.Then these are every where:
Technical Advisor Shanna Simmons said it is a myth that engines need to idle on a cold winter day.
"While it does take longer for motor oil to pump in extreme cold temperatures, we are talking milliseconds, not minutes," she said. "Your engine will warm up the oil much faster when driving at full speed — not to mention idling wastes gas."
The Environmental Protection Agency lines up with those who say warming up your car is not only not helpful but is wasteful.
Both the EPA and Energy.gov say a car should not idle for more than 30 seconds at a time. Not only is it more environmentally friendly, but also cost-effective. Idling for 30 seconds actually uses more fuel than restarting the car
In major cities, officials restrict how long the average driver can idle his/her car. Minneapolis, for example, limits the length of idling to three minutes, barring some exceptions (when it is below zero degrees Fahrenheit or higher than 90, idling is permitted up to 15 minutes an hour).
Chicago, New York, Philadelphia and Boston have similar regulations. Those caught idling for too long can face a fine.
All experts agree that drivers should take it easy in the first few minutes of driving. Henmueller suggested driving no more than 45 miles per hour for the first five to 10 minutes.
https://www.accuweather.com/en/weat...ther-experts-explain-engine-oil-life/55447779
I am not saying i agree, I am saying the average reader now days is being hit with this non sense 5 or 6 times a year just in their daily review of the headlines.
It is also hard to abide by BOTH the rule of "only 3 minutes" and "keep it under 45 for 10 minutes" if you literally pull out of your drive way and almost RIGHT onto a 70mph freeway. The two rules are just not possible. You can do one or the other...NOT both.
There is also probably significant wear difference between people like me who may rev the engine at cars and coffee right after starting it up once or twice a year or who may have to pull out into traffic while the car is still cold a few times a year and the guy who literally does both nearly every single time he drives...
And it is on "car" sites, "tire" sites etc.
Don’t let your car idle for long periods of time to warm it up.
If you’ve gotten into the habit of starting your car 10 or more minutes before you need to leave, it’s time to change that habit. Many of us have been taught that allowing the engine to idle will “warm it up.” While true, most manufacturers say it’s actually no longer necessary. Instead, start your engine, wait 30 seconds, and then gently drive away to warm the engine gradually without wasting fuel.
https://blog.firestonecompleteautocare.com/driving/get-better-fuel-efficiency-cold-weather/
Again, if someones house dumps right into a 55 to 80 mph zone nearly (mine does) and you think "ok i wont let it warm up long" where do you end up? 90 seconds of running and you are merging into highway traffic at high speeds....
I don't follow any of the advice for that reason but you can see how this can be a huge problem for those who's houses are right off high speed areas.
I know in some places there are folks whos drive ways literally pull out into a 55 mph zone..of which the entire flow of traffic is going 75 in the morning rush hour...
Nah, the EPA could not possibly have their own agenda here . . .Then these are every where:
RESTARTING, not initial starting. This is for after you've already driven somewhere and the engine/oil/coolant is presumably no longer stone-cold. Not the same thing.Both the EPA and Energy.gov say a car should not idle for more than 30 seconds at a time. Not only is it more environmentally friendly, but also cost-effective. Idling for 30 seconds actually uses more fuel than restarting the car
Why do you 'have to' jump right onto that freeway? Can't you take a longer way around? Or at least head away from it and make a U-turn so you run up at least a few tenths of a mile at reduced speed. I can't remember when I didn't do one or the other of those, given that I'm only about a mile and a half from a major East-coast Interstate highway.It is also hard to abide by BOTH the rule of "only 3 minutes" and "keep it under 45 for 10 minutes" if you literally pull out of your drive way and almost RIGHT onto a 70mph freeway. The two rules are just not possible. You can do one or the other...NOT both.
Also why you might choose to run the thinner of two viscosity choices in the winter, especially if you intentionally run something slightly 'heavier' for track and autocross purposes.I guess this is one area where the "thinner" oils that OEMs now run to increase fuel economy may help significantly
Not quite that bad for mine, but close: out of my driveway, 1.25 miles to the end of the street at ~35 mph, left turn, 1/4 mile to the downhill ramp, and turn right onto the interstate, average speed ~75 mph in right hand lane. Same thing at the office: left turn out of the lot, 1.75 miles down the street at ~45 mph, right turn onto an uphill ramp for the same interstate going the other way.I don't follow any of the advice for that reason but you can see how this can be a huge problem for those who's houses are right off high speed areas.
