MikeMM
So I have a Borla exhaust on my 350 and I couldn't find a thread with this exact issue so I started a new one. Shortly after installing it I started to get a "Exhaust Mode not available" message which also prevents me from swapping the drive modes, and the passenger side valve will get stuck either fully open, fully closed or halfway. It's always the passenger side and never the driver's.
Usually turning the car off and back on a few times, letting it run through it's valve cycling will fix it. Sometimes it have to cycle it 20+ times. Once it fixes itself and decides to start working again it will open and close the valves via the toggle, mode switch, and 5-6 and 6-5 gear shifts no problem; until the next time it wants to be temperamental after I shut it off. I installed the exhaust myself and took extreme care when mounting the valve motors and reconnecting the electrical connection. Anyone have any ideas before I get it up on jack stands and rip the muffler back out? My only thought was a loose electrical connection but I did check the connector and it appears to be tight. Of course to do that I had to contort my arm around everything so I don't know how accurate that is..
As a note: I have checked for pebbles, burrs, debris and anything else in, on or around the butterfly itself and I can never find anything. Gently poking the valve with a rod shows me that it can move and isn't seized when it's stuck in any of the 3 positions I mentioned earlier. It seems to mostly do it when it's hot after driving it for a while, but it has done it cold too.
