Exhaust malfunction?
Avega96
CA
Anthony
2017 Mustang GTCS
Does anyone know why my exhaust is doing this on start up? I have a corsa exteme cat back exhaust with the AWE switchpath
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
It stops once the car settles down
greasy
Grayslake, IL
Jim
2021 Velocity Blue Mach 1
It’s not an exhaust issue, sounds like your engine is surging. What do the RPM’s look like?
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
The rpms seem to hold steady like they usually do
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
The RPMs can’t be steady lol. Take a video showing us the steady RPMS?
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
It sounds like the exhaust flap is opening and closing rhythmically. Is it both of them, or just one side?
greasy
Grayslake, IL
Jim
Isn’t the AWE Switch Path a catback? How can you have 2 catbacks on the car?
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
I just tried to take a vid to recreate noise and show the RPMS but I just drove it not too long ago and it seems to only do it on a true cold start.
Here’s another vid I have of it with the valves closed on a cold start
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
No it’s a modification you add to your exhaust
greasy
Grayslake, IL
Jim
What is the modification? Is it an extra set of valves? Maybe that’s the problem, the valves aren’t operating properly in a cold start scenario.
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
It lets you manually open and close the valves with a remote so they don’t close on their own on cold starts or in 6th gear. It was actually making that little rattle in the video posted above with the valves closed before I added the switch patch
Mike Pfeifer
Wesley Chapel, FL
Not sure if you can physically see the valves in the exhaust or not, but if not, maybe listening at the back of the car when it’s happening will be able to indicate if it’s one side or both sides that are opening and closing. If it’s one side, it may be a faulty actuator that lost its position sensor. If both sides, it may be a controller issue. Perhaps the manufacturer has a trouble shooting path to follow or maybe even has come across this issue before.
Skye
≈39N
"Skye" Mach1 N2144
Avega96
Avega96
CA
Anthony
2017 Mustang GTCS
Here you go a video of the RPMS holding steady like I said lol. I can hear a beep every time it goes back and forth so there’s definitely something malfunctioning with the exhaust
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's most likely a loose clamp or something else that stops vibrating once it gets hot.
