Cati
- Nov 21, 2015
- U.k. Down sarf
- 2015 get v8 ucl mag grey & e93 m3 cp
subbed
...and why? Is this common practice? [apologies for the mech-deficient question...I've not changed oil in decades...]Where did you source the sump plug?
If it has a copper crush washer or rubber 'o' ring that holds it from vibrating loose it's a good idea to change it when changing the oil. Less so with an 'o' ring unless it's getting on a bit. You used be able to just change the washer....and why? Is this common practice? [apologies for the mech-deficient question...I've not changed oil in decades...]
I got a couple of spare plugs chucked in with my order from Levittown.....If it has a copper crush washer or rubber 'o' ring that holds it from vibrating loose it's a good idea to change it when changing the oil. Less so with an 'o' ring unless it's getting on a bit. You used be able to just change the washer.
