Engine ticking / knocking... Help!
Weather Man
Persistance is a Bitch
MN
2015 I4 T Prem Auto
I would be concerned with cylinder wash down with amount of fuel in the oil. Tune should be looked at.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Have you taken any logs recently to check the lambda? If your car is running really rich, you can look at the plugs and tell.
emh87
emh87
Akron, OH United States
2015 Black Mustang GT Premium 6MT
Until the fuel dilutes it again.
Do you do lots of short journeys in the car?
What would short journeys cause? I don't feel like I do them too often.
The tune has been finalized for a while now, and I've never ran into this issue until recently. I've had the tune for like 9 months now.
I will take some logs, and check out the plugs. On the last logs at WOT the car was pulling around an average of about 12.0 AFR
mustang1
Dallas, TX
can the car run so rich that it ruins the oil and not set off a CEL ? How else can gas get into the oil ? I would get the car looked at by a mechanic asap. One that has the fancy Ford scan tool. Gasoline in the engine oil sounds like it could do bad things to an engine.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
12.0:1 WOT is lean especially with FI. I'm assuming that Lund tuned your car. When I was tuned by Lund, mine was around 11.2:1 which is a little rich.
